Question about Phase Linear UDV9010 Car DVD Player
How do i use my tv without using my parking break
I want to hook up my radio and tv and bypass the parking break in my 03 dodge neon
You either need to run a toggle switch or get the bypass code and follow the steps to enter it with your remote..
Posted on May 03, 2009
Blue power antenna wire is causing radion to stay on all the time what should I do
The 3rd wire is coming from the bypass switch. I have the solid blue wire from the unit the blue and white from the jeep and the bypass wire all hooked into one. Is there another wire I could hook the Blue wire too I had two yellow wires coming from the radio one is with the yellow wire from the car the other is capped off could I unhook the blue from the blue and white/bypass and hook it to the other yellow possably?
Apr 15, 2014 | Pyle PLTS78DUB Car Video Player
2005 dodge neon - revs high in park nuetral and tough to push break pedal down. mechanic doesn't know what it is. Anyone have this problem resolved before? Thanks
sounds to me like you have a vacuum leak. When you lose vacuum the brake booster doesn't operate right. You need to go too a different mechanic. Could be the idle selonoid staying open or even a bad brake booster or vacuum hose came off.
Jun 13, 2012 | 2005 Dodge Neon SXT
When I see video of my radio dvd pd 733bt pyramid, the display says Frease the following: parking brake audio only! what should I do to get out of the sentence is the display?
That is because it has a safety on it to where you can only watch videos when in park. It doesnt want you watching movies while driving. Easy to bypass if you know what your doing. There is probably a wire on the back of the stereo that is in a bundle that you did not use? It should be relatively long. Maybe add a bit of length to it with some more wire and hook it to the ground on your battery if that doesnt work put it on the positive. Sorry i remember doing this in my camaro dont remember if its pos or neg but you are suppose to hook that wire to somthing on the parking break. Hooking it straight to the battery will bypass the parking break safety.
Jun 07, 2011 | Pyramid PDVD78 Car DVD Player
Radio just stoped working i hooked up an amp and 2
the acc wire may have been disconected. its the on that tells the radio that the ignition is on
Feb 10, 2010 | 2002 Dodge Neon
"fuse"
Had a similar problem. Apparently the driver had driven a little too far into a parking place and struck the front of the frame (Neon has a low frame) with the concrete parking block. A wire got pinched and eventually failed shorting that fused wire to ground. Check that. It fixed my daughters 2001 Neon and it now starts and runs. BTW, do the turn signals work. With mine, the headlights worked, the radio worked, etc but the turn signals didn't work and the car wouldn't start. My problem was found by a 'fantastic' mechanic, not me.
Aug 17, 2009 | 2003 Dodge Neon
Where to wire the e brake so i can have video
Use the parking break bypass procedure, and there is no need to even hook up the break wire.
The parking brake bypass procedure is as follows:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Aug 09, 2009 | Jensen's VM9312 Car DVD Player
2000 dodge neon
If your brakes are drums take a hammer and tap lightly on the drum it should break up the locking
Jun 16, 2009 | 1998 Dodge Neon
How do you get the rear brake drum off?
2003 dodge neon sxt
Here are the steps;
) Park on a level surface. safety
) Block all the other wheels. safety
) Put the vehicle gearshift in PARK. safety
) Release the handbrakes.
) Slightly break the rear wheel lug nuts seal while on ground. Just loosen do not remove.
) Jack up the rear wheel.
) Check to see the wheel will turn so you know the brake shoes are not binding against the drum.
) Now you can remove the lug nuts and wheel.
) Remove the drum. Some times the drum has frozen on with rust. You may have to use a hammer and hit along the drum near the outer edges to break it free.
May 08, 2009 | 2002 Dodge Neon
Jvc KDAVX44 install issue
Try grounding the parking brake wire instead of attaching it. Should bypass brake requirement for video but really should effect powering on
May 10, 2008 | JVC Car Audio & Video
Trying to find the parking brake
YOU DONT NEED TO HOOK THE PINK WIRE UP JUST PUT IN A DVD AND TYPE IN 543210. THIS IS A BYPASS CODE SO YOU CAN PLAY DVD WITHOUT HOOKING UP THE PINK WIRE. YOU MUST HOLD DOWN THE 0 FOR 4 SECONDS WHEN PUTTING IN THE CODE.
Jan 15, 2008 | Jensen VM9510 Car DVD Player
Phase Linear UDV9010 Car DVD Player Logo
186 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
