Question about Panasonic Audio Players & Recorders
How to program Panasonic SA-CH94M
Panasonic home stereo SA-Ch94M doesn't advance to next CD.
Plays one CD, then doesn't advance to the next. It worked once, then I did something (not sure what), and has not advanced since.
How can I program stereo to advance to the next CD when finished playing the first?
SOURCE: Panasonic SA-PM193 5cd stereo system
how do I have all 5 cd's play one after another automatically?
Lost our manual.
Thanks
Posted on Jun 19, 2008
tech48
  • 624 Answers
SOURCE: POSSIBLE FAULT CODE
Yes, it is possible. The F61 error is a failure in the power supply or the amplifier. I repair these every day and it will require good soldering and troubleshooting skills to fix this yourself.
If you would like to try, let me know, and I will give you more information. But the best thing to do is take it to a service center and let a professional technician check it out for you.
Posted on Jul 01, 2008
SOURCE: panasonic stereo (model sa-pm19)
I still need help!
Posted on Aug 02, 2008
  • 189 Answers
SOURCE: I WHAT IS FULT OF F61 IN SA-AK177
HELLO
F61 means a protection code which normally means there is a fault with the audio output IC. Check all your cables for shorts etc, and try hooking it back up. If the error is still there you'll have to put it in for service.
ALL THE BEST!
Posted on Sep 01, 2009
SOURCE: cd jam in panasonic sa-pm17
Hi. Got the very same problem. At christmas I had loaded two cd's in one of the racks. I used needlenose pliers as well and pulled each of the 5 trays out (well past their runners). Tried to dismantle the unit with the 3 screws on each side, but gave up. When I turn the power off and on and do a cd check the "hello" flashes then nothing, tried cd/change power button and basically everything else. All I can say is go easy on the unit as I was to forceful an now think i've ruined it. I'm gutted as this was a great mini hi-fi and has served me well. Best of luck with ur Panasonic, cheers.
Posted on Jan 22, 2010
Panasonic cd stereo system sa-ak87
F61 is a faulty amp IC - IC need to be replaced
Jul 28, 2014 | Panasonic Audio Players & Recorders
Would any one be able to get a part #, cost for the regulator, for my Panasonic SA-CH94M? I believe this is the culprit with the F61 error code. Thanks!
the F61 error on panasonic home theatres can mean 1 of 4 things, its either you have the wrong speakers plugged into the wrong port (yes apparently this matters check correct speaker placement), the fans are not working at all or working poorly (simply clean with circuit board cleaner or replace fan you may have 1 or 2) if none of the above then you have the worst one wich is one of your power amplifier IC chips somewhere on the main circuit board has died (good luck fixing that one) obviously varies from model to model this is based on th SA-HT545 and the SA-PT450. Sometimes a new HDMI cable will solve this issue.
If the cables are good, then the easiest possible fix would be to clean or replace the rear electric fan. I had the same problem and after replacing the fans my unit works like new. I called panasonic to order the fans because these type of fans you can not buy out of any store. The rear fan is also an upgrade to a better bigger fan. Part numbers are: L6FAJCCH0007 $19.12 (side fan) RFKZHT540E $28.35 (Rear fan) total shipped to me was $61.43.
Happy Holdays! Dont forget the feedback! Thanks!
Dec 18, 2010 | Audio Players & Recorders
My Panasonic SA-HT75 won't read any DVD/CD discs
The laser has failed. They all go this way. Throw it away and don't buy Panasonic next time.
Jun 09, 2010 | Panasonic SC-HT75 System
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
My panasonic sa ht7o plays dvds fine but no
you have it hooked up as a component with one of the three video cables crossed
Aug 24, 2009 | Audio Players & Recorders
SA-HT 900 only plays music in flat surround mode no others work
I plugged some headphones in and then unplugged em and now my stereo only has abass sound . The stereo speakers seem to be broken . Have you ever heard of this problem before ?
Jan 29, 2009 | Panasonic Home Theater System System
Error f-61 on SA-AK640
F61 Power Amp IC output abnormal
Upon power on,
PCONT=HIGH,
DCDET=L after checking
LSI.
For power.
Press [STOP] on main unit for
next error.
Aug 23, 2008 | Panasonic SC-AK640 Shelf System
Panasonic SA-AK66 Sound Problems
I have a Panasonic SA-AK66 5 disc changer stereo system. At first I was getting a no disc. I inserted my cd disc cleaner, now it won't play the disc or open (the drawer). What happened?
Nov 26, 2007 | Panasonic Audio Players & Recorders
322 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
