Question about Fisher SLIM-1500 CD Shelf System
Cd does not spin
I put in cd and push play, and most of the time it TRYS to go around, grunts and groans but cannot go around. If I open the door, spin the disk counter clockwise, and quickly close the door and push play again, I can get the disk to play (sometimes after many tries).
  • 11,896 Answers
The motor will need to be replaced
Posted on Apr 15, 2009
I took out all discs. When I tell it to play a disc the table moves back and forth slowly about an inch. After a couple trys "Table Error" shows up. Both belts are old but on.
Tray will prolly need retimed after the belts slipped off the pulleys.
Procedure is with tray brackets removed lift tray in back then push open button to let the cam gear spin around to open position. Then let tray down and try to close it with button. Reinstall brackets and may take a few attempts to get that gear in the right position!
Dec 16, 2014 | Sony CDP-CX300 CD Player
I have a 2010 ford fusion and the driver power window will let it go down but not up. It will allow it to go partiallup and then the window will go back down. What causes this?
replace window motor it should come with the window regulator as well. it takes more power to push window up then down. wore out motors will act like this. the fact that it trys at all tells you the switch,relay and circit breaker are good
Apr 16, 2013 | 2010 Ford Fusion 2.5
Will not spin correctly , slow spin
open the door,remove the screws that hold the door on and the two screws accross from them,pull off the front panel gut keep the door on.now remove the two L brackets that hold the top on,lift up the top.put the machine in the spin cycle and see if the wax motor is pushing the plunger all the way over to make contact with the micro switch,the lock door light will lite and then a few seconds after the plunger should hit the switch,if it doesn't push the black plastic button piece in on the switch a few times and listen for a clicking sound.if it's clicking put it back into spin and after the door lock light comes on push the black button in and hold it in to see if it spins in high spin,if it does change out the micro switch.or with a meter put the tester wires on the clips that the wires slide onto and push the button in and out and see if it opens and closes,if it checks good and it spins on high spin when you push the black button in then you have a bad wax motor,it's not pushing the plunger over all the way.if both parts are good then you have a bad inertial switch.it's on the right side of the tub,you have to pop off the right side boot seal and remove the screws that hold the right side of the front shroud in place,pull the right side of the shroud out so you can get your hand in there to remove the inertial switch and change it out. part number 22003302.it's around 40 dollars.i couldn't find the micro switch or the wax motor but you can give the parts store the model number and they will help you out.a few times it was the micro switch so i would start there.let me know how you make out
Jan 22, 2011 | Maytag Neptune MAH5500B Front Load Washer
I bought a new frigidaire fridge with the freezer on top. It's made a weird grunting, gurgling, groaning sound on and off from day one. Should have called Leon's where I bought it to complain but never...
hmmm, could be in defrost cycle when that happens, when the defrost element warms up and the frost/ice drips it then makes sounds about how oftern do you hear the noise?
Dec 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
ABS brakes grunt, groan noise with brake pedal travel.
Joe it is common for the brakes to moan when they wear down and sometimes they will squeak, try replacing the front pads and lubing the shafts on the calipers install anti squeal on the back of the pads, the ABS device would not cause noise as they are just a ring with a magnet and the reluctor ring spins and the magnet detects the spinning of the reluctor ring, they don't even touch and are stationary in place where they are mounted. There is a possibility that the brake fluid is dirty and could cause the abs motor to groan but you would just have to flush the system, When you don't put your foot in it on the brakes it will make some noise even new, I have a 2008 ford ranger that makes the same noise and the brakes are fine. You will have to adjust your braking habits to stop the noise. You can change the pads and that will help but not for long, be sure when you are operating your brakes press firmly on the pedal until you stop. If the brakes make noise after you let up on the pedal then the caliper parts need to be cleaned and lubed, however it is not a safety issue.
Jun 13, 2009 | 2005 Chevrolet Silverado
Stuck cd discs
I think there are a couple of faults here. The first one is maybe a faulty motor on the eject mechanism. The second one is a faulty laser unit as it is not scanning the disc. Hope this helps.
Jul 25, 2008 | Sony RCD-W500C 5-Disc CD Recorder
Onkyo c707chx...
This is an easy fix if you are somewhat handy.... The belt for the door/tray is slipping. If you remove the enclosure and face plate, you will see two motors below the disc drive. Press eject while observing the pulley to the left. You should see the problem with the motor shaft spinning and the belt slipping. Replacing the belt is possible without any further dissassembly. Simply bend some light wire into an L shape and you should be able to hook both pulleys and lace the new belt on. As far as obtaining a new belt I decided to do the simple thing and use a slightly smaller rubber band. The repair has held now for almost three months and the player is used everyday. Good luck.
Jun 21, 2008 | Onkyo MC35Tech CD Shelf System
Machine not feeding paper through
try cleaning the rubber rollers with a damp cloth and make sure there clean. also check to see if the paper is making contact with paper.
if that fails check the leading edge of the paper for damage incase something maybe blocking paper.
May 07, 2008 | Canon FaxPhone B95 Plain Paper Inkjet
Fisher SLIM-1500 CD Shelf System Logo
202 people viewed this question
Top Fisher Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
