Question about Dell Inspiron 3500 Notebook
Cd rom not recognizable, but came with laptop?
Dell inspiron 3500 does not recognize cd rom, it is a removable drive and I tried using it from the cable and inserting it into the slot...it won't run from either and on the devices list there is no cd rom????
  • alandryis Apr 16, 2009
    When I went into the devices, there is no cd rom listed?....where do I get into the system manager?? From My Computer? or the control panel? By the way, thank you for responding!!! You are awesome...........
  • 526 Answers
It sounds like you have a bad cd-rom. before replacing, you might want to try deleting the cd-rom drivers from the system manager and see if that helps.
Posted on Apr 15, 2009
I re-installed windows and low level formatted the hard drive, and now the bios won't recognize the cd rom drive. I also ran the bios utility that comes with dell... what can I do to fix this problem. I...
Even if you don't have driver for CD-DVD ROM with the Operating System,your BIOS must recognize the CD ROM.Set the BIOS to Default setting and check it recognise now.Check if you have disable anything related to CD ROM in your BIOS. Remove your CD Rom and place it again and check.
Drive light comes because of power supply to the CD-ROM.
If nothing works,Download the firmware update
Here is the download link
ftp://ftp.us.dell.com/rmsd/R104295.EXE
Jan 04, 2010 | Dell Inspiron 1000 Notebook
Won't recognize CD, it makes a lot of noise, like if is running but nothing happens. (Dell inspiron 1420 laptop)
U need to reinstall the driver for you cd/dvd rom drive u can do this by "Start right click computer select properties click hardware tab ,device manager then dvd/cd rom drive uninstall driver then click action tab check for hardware change i should be gone after this step go to the dell web site and download the correct driver for your cd/dvd from the web site here is the link http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen this should fix the problem hope this helps
Oct 11, 2009 | Dell Inspiron 1420 Laptop
Dell Inspiron 3500 can't find CD-Rom drive. It lights up and opens and closes, but can't install anthing or get the Windows 98 to find the drive. Any suggestions other than buying a new drive? Thanks,...
Hello there:
you may want to contact dell support www.dellsupport.com they should be able to help you get the right driver for the cd rom. If not you can go to www.radarsync.com and use this free utility it will scan your entire system and give you options to down load updated drivers and drivers that are not installed in the system..
hope this is helpful for you.
best regards mike
Jul 17, 2009 | Dell INSPIRON 3500 INTERNAL 56K MDM...
CD not being read from CD/DVD ROM Drive on Laptop
try to clean the cd drive lens with a lens cleaner...
Jan 30, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 1150 won't turn on
Remove the battery the memory the ac adapter,the hard drive, the cd rom.Press and hold the power button down for twenty seconds.try again if no go you will have to replace the systemboard.
Good luck
Jan 13, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Dell CD/DVD shows up in 'My Computer' but doesn't recognize CD's
the cd player could be bad it doesn't seem to be reading anything. or your windows needs reloading because you have other programs overwriting each other and windows.too much on the drive defrag it
Dec 27, 2008 | Dell Inspiron 2200 Notebook
Dell inspiron 1526 laptop
double-click MY Computer
Double-click the CD Rom Drive
You should see a file called setup, double-click it, the install should run
Jun 21, 2008 | Dell Inspiron 1501 Notebook
Basic Info on a DELL Inspiron 3500. Easy to answer
you can find the basic and upgarde info at the below mentione link
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?c=us&l=en&s=gen&SystemID=INS_PNT_PII_3500
select the system confi option to view the factory config deatils and the upgardes option to check for upgrades.
if u go to manuls u will be able to get the system specifications as well as minimum and maximum supported.
Mar 24, 2008 | Dell Inspiron 3500 Notebook
Dell inspiron 8200
Check your BIOS make sure your HDD and CD-ROMs are enable I did the same thing and found i had been laying to much in BIOS
Oct 13, 2007 | Sharp Dell Inspiron 8200 15.0 ASV UXGA -...
Dell Inspiron 3500 Notebook Logo
82 people viewed this question
Alun Cox
