Question about Sony Xplod XM-554ZR Car Audio Amplifier
Xplod amp i had friend hook it up an i unpluged everything to move and now i don't know what goes where xpect for the grounder
  • 150 Answers
You have 3 power connection, +12v goes directly to your vechile's battery (make sure this is fused) REM connects to your head unit which tells the amp when to turn on and off (usually very thin wire, comnpared to the gnd and +12) Te gnd you already know where it goes. Then connect your sub to + and - speaker out put. If you run this bridged it will increase your output, must be 2 channel to bridge to 1 channel or a 4 channel bridged to 2 channels. Hope this helps.
Posted on Sep 14, 2007
I have a 1200 w sony xplod amp, with 2 caps, hooked to my sony xplod 1200 w 15s, I just need to know what size inline fuse I need to have connected to my power wire to my battery? I have a 40A that keeps...
with no signal input the fuse should not blow ,if it blows then the amp has a short on it ,if it blows when the volume is turned up really high the try 60 amps .
Jun 18, 2010 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
I just got a sony xplod 1000 watt amp i got everything hooked up and when i turned the key the power light chaned from green to red. i check over the amp again and again, i cant find any thing wrong........
Try disconecting all speakers from the amp, turn it on after and if it stays on red it sounds like it had kicked the bucket. if it stays green start from their and check all of your wires for shorts (speaker wires) again. hope this helps...
May 08, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
I have an sony xplod 4 channel 600 watt amp
First are they in the same box? If so and they are sharing the same air space running one amp to both is best andwill perform better. One woofer could be over powering the other and or you could have a woofer problem. A lso your wiring coul be problem. When amp is bridged it changes the OHM reading and output your other woofer may not be rated at or able to handle a lower Ohm rating also it coul blow that woofer if it hasn't already hapened . Be careful. check woofers independently for operation and check the non performing woofer on an unbridged power source or amp. Hope this helps. Write back if not.
May 06, 2010 | Rockford Fosgate P112-200 Car Subwoofer
Sony Xplod Amplifier Problem
First make sure you are using at least a 12 guage speaker wire for sub connections. Second make sure you have plenty of breathing room in your mounting position, these things need air badly. Third of all, Xplods are not very friendly if they are cranked all the way up on your dB boost knob. Only crank it about 3/4 of the way up, then use your equalizer settings to tweak the thump.
Oct 20, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Subs and amp problems
make sure you have the wires from the amp to the box, and the box to the subs hooked up right... red is positive black is negative
Dec 28, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
How to measure watts
You need a Volt Meter and an Ohm Meter. P = VI & I = V/r, so Power = (Volt^2)/Ohms .
You can get the ohms by hooking them up to the subwoofer input wires, and you get the volts by hooking up to the amp output terminals/wires. Although, amps will put out different voltages for different frequences, this should give you ballpark estimates.
Nov 10, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony xm1652z amp problems
it sounds like you have the high lvl inputs on the amp hooked up instead of the rca's. this will cause the boominess for a few seconds when the amp is on and right when you turn it off
Jul 11, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
My Amp
sounds like the sub that throws it into protect mode is cross wired pull sub out and make sure they are wired right make sure ground from sub goes to ground on box and do same for power wire
Jun 11, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Thermal light won't turn off...
Check your speaker load ESPECILLY if you are bridging your speakers. Sounds like you may have a very low ohms load and it is frying your amps. Do this BEFORE you hook up another amp. If you are using dual voice coil speakers it is very easy to get the impedence (ohms) wrong in your hook up. If unbridged then a 4 ohm load per channel is good. If you are bridged, then an 8 ohm load is best. When you combine speakers, that is when most people get in trouble. Good luck.
May 09, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
One hits harder then other
A faulty voice coil may be to blame on one of the subs...when it heats up it starts to act up leading to a undesired preformance.
Feb 01, 2007 | Sony Xplod (P589) Car Subwoofer
Sony Xplod XM-554ZR Car Audio Amplifier Logo
189 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
