Question about Cycling
I have second hand bike for my son with a peddle missing , so i am trying to take one off another bike but it is either rusty or i need a puller or something like that . don't want to keep trying if i need a special tool
  • lisa44965 Apr 16, 2009
    i needed to remove arm also not just peddle, thanks
    President:
  • 3,113 Answers
One side has right hand threads and the other has left hand threads. You should get it done with an open end wrench.
Posted on Apr 15, 2009
How do I change a Bicycle Peddle arm? what tool do I need how much dose this tool cost?
It's called a crank arm, and the pedal (not peddle) is attached to the end. Usually one uses a crank puller, but as you have not said exactly what model bike you have or provided a close-up picture it's hard to advise you in more detail. Google "remove 3 piece crank arm" for help.
In the future please put as much into proper spelling and details you provide as the effort you expect others to take in answering your questions. Although "dose," "peddle" and "stile" are actual words they are not the same as "does," "pedal" and "style."
Apr 30, 2017 | Mongoose Cycling
How do i install pedals
Right peddle has a right hand thread, normal, and left peddle has a left hand thread. On the left peddle you need to turn it clock wise to loosen it, counter clockwise to tighten
Aug 07, 2014 | Shimano SPD Mountain/Spinning Bike Cleat...
How do you remove the master link on a bicycle?
older bikes had a master link, back peddle and watch for a link that is different from all the rest. take a screwdriver and open up { looks like a c clip but stretched out} remove that and it should be easy from there. Newer bikes, don't have a master link...because there is not enough space between the sprockets for the extra clip.. you need a chain puller and it will open any link you want, ask the bike shop you get it from how it works, or follow the instructions that come with it
Jul 01, 2013 | Cycling
Can't get flywheel off, tried pully puller, after removing nut and washer , am i missing something. it's B&S 446677-0463-e1
No you are not missing anything....they are pressed on and then with the heating and cooling they will need to be heated to get it off....focus the heat on the flywheel hub along with tension from the puller... then tap on the puller to get it to come loose...most times it pays to have an extra set of hands when doing this...
heatman101
Sep 16, 2011 | Briggs & Stratton Briggs Stratton Intek V...
My son peddle came off i guess his bolt that holds the peddle together got worn out is there a replace part for it....i juss need the screw that holds it together he has a smartcycle bike the 1st 1 they...
Most peddles have to simply be replaced when the bolt is damaged. There is no way to replace the part. They have new peddles for all kinds of bikes at your local bike shop.
Nov 08, 2010 | Cycling
Repair peddle on Huffy Incline 26
Try screwing it on by hand in both directions as one peddle screws in clockwise and the other anti-clockwise. If this still does not work look at the thread on the peddle and see if it looks threaded (damaged). If it does then you need a new peddle or set of peddles and a visit to your local bike shop can confirm this for you.
Jun 12, 2010 | Huffy Cycling
Choke not working
as i remember yhe choke is not adjustable
this is asimple carb and may just benefit a simple strip and clean.The carb flooding may just be down to the float jet not seating properly due to dirt on the seat
hope this helps
Dec 27, 2008 | 2006 Honda CBR 125 R
How to get flywheel off?
you need to really crank down on that flywheel puller. even when they are not rusted they are dinks to get off. i wouldn't give it heat. i'd soak it in an oil. and hten really torgue her down. should pop right off … Joe
Nov 10, 2008 | 2004 Yamaha YZ 125
Nov 10, 2008 | 2008 Yamaha XT 660 R
Cycling Logo
35 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
