Question about Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
Router wont connect to the internet
I was trying to set up a password so no one else would have access to my wireless internet so, i went on the WEP feature and on the first security key box, i deleted what was on there and replaced it with another number thinking it was renewing a password. when the connection started restarting, i immediately lost connection to the internet and now my computer detects the router but it wont connect to the internet through it. right now, ive gone back to using the lan cable. PLEASE HELP, I need my network back asap. thank you!
  • 41 Answers
Two things, first try power cycling the modem and router. Unplug both of them for about 30 seconds then plug the the modem in first let, let it cycle through and then power up the router. If that does not work you might need to reset the router and restore the factory defaults. Let me know how it goes. Thanks
Posted on Apr 15, 2009
WHERE DO I FIND MY WEP KEY? I AM TRYING TO CONNECT MY PS3 TO THE INTERNET
WEP key is also known as your Wireless password. It is located in your Router Configuration settings. Access the default gateway of your Belkin Router and go to Wireless Settings. Look for WEP and it will provide you the WEP password to connect your PS3.
Jun 20, 2011 | Belkin Computers & Internet
My router seems to be destroyed. i tried to setup access point but right after that the light went red.. but i connect wirelessly. and my fone and my sisters' laptop can't connect to the internet...
You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 16, 2011 | Belkin Surf N300 Wireless N Router
Cannot connect linksys wireless broadband router with at & t dsl modem to connect to internet ?
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Then check
Jun 05, 2010 | Linksys Wireless-G WRT54G Router
Where do i find the wep key if every ip adress i type wont work?????????????????????????????????????????????? HELP!!!!!!!!!
Logon to the computer with the wireless router connected to the modem. Use the software that came with your router to select the Wireless setup. You will see the Wired Equivalent Privacy (WEP) key that you must use on all computers using the wireless connection. If the software is not installed you could access the firmware from Internet Explorer. If you do not know the router address you can find it by the next steps.
1. Select Run from the Start menu.
2. Type CMD and press Enter.
3. Type IPCONFIG /ALL and press Enter.
4. Note the Default Gateway on a piece of paper.
Open Internet Explorer and type the Default Gateway in the Internet Explorer address bar (example: 192.168.0.1). You may have to type a username and password to access the firmware settings. You should find the password listed in your manual, possibly on the bottom or back of the router. Once you are in the router firmware find the wireless settings so you can see your WEP key and note that value on a piece of paper. Exit internet explorer to save your settings and again try to scan for wireless networks on other computers. Select your router and type in the WEP key and you should be wired.
Apr 06, 2010 | Computers & Internet
Dsl wont pass thru router wired or wireless I have reset the router several times, the computer shows connected ,signal strenght excellent, but will not connect to the internet wired or wireless as long as...
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Mar 28, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Where do I find my WEP key
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address, 192.168.1.1, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your change
Nov 21, 2009 | Linksys Wireless-G WRT54GS Router...
How do I get my WEP Key for my LINKSYS ROUTER
Nov 12, 2009 | Linksys Wireless-G WRT54G Router
Network wont show up on any Wireless Network List
Reset your router to factory defaults.
For that press RESET button for 10 seconds it is in back panel of router.
hen connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Thanks.
Nov 10, 2009 | NetGear WGR614 Wireless Router
Using the router
First connect your router to computer then access your router as following link.
http://192.168.1.1
or
http://192.168.0.1
Then you can see configuration page .
Then set WAN settings as your internet service provider settings.
Enable DHCP.
Go to wireless enable wireless.
SEt wep security if you want secure wi fi.Add WEP code it is your password to connect internet so only who know the password are connect to your wi fi .
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | Actiontec GT704WG Wireless Router...
Wireless Connection Not Identified Aftre Password Was Set Up
There are a lot of reasons this could happen but I'll give you what I had to do. 1) Go back into your router and change the Wireless channel from 6 to 10. 2) make sure you have entered the correct WEP key in your network setting for the wireless adapter. The easiest way is to remove teh wireless network from your computer and let the computer find the network and prompt you for the wep key. the wep key is not the password you use to log into your router. The wep keys must be entered on all the wirelss machines in order for this to work.
Aug 28, 2009 | D-Link AirPlus DI-524 Wireless Router
Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH Logo
230 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
