Question about Panasonic KX-T7630 Corded Phone
Model KX_T7630 Need to find the voicemail function???
We have 3 handsets linked to 2 phone lines, all on the same number and when 2 people are on the phone we need voicemail to pick up the calls. At the moment, if 2 people are on the phone and a third caller tries to contact us, they are either cut off or hears the engaged signal.
Can you tell me how to programme voicemail and how to divert the caller to the next available phone?
  • Carl Navarro
    Carl Navarro May 11, 2010
    Is this a math quiz? Two lines two calls. There is not a path for the 3rd call. You either get Central Office voice mail, or add additional lines.
Apart from needing more phone lines, the main solution was to use the TVM50 Voicemail instructions and not the guide that came with the KX_T7630 so the earlier Panasonic is a good place to start!
Posted on Apr 15, 2009
NEED USER MANUAL FOR KX-TAG931S PHONE HANDSET What I really need is how do I make the incoming call go to Voice Mail without it ringing 4 times.
You may download the KX-TGA931 manual from http://shop.panasonic.com/shop/model/KX-TGA931T?support
The number of rings is controlled by the answering machine or voicemail system on your phone line. It cannot be changed from the handset. Please refer to the documentation for whatever answering machine or voicemail system you have.
If you require further assistance with the answering machine or voicemail system, please tell us the make and model.
Sep 23, 2013 | Panasonic KX-TG5210M GigaRange Supreme 5.8...
Two questions: We have Panasonic KX-T7630 model How do I change/delete numbers to the personal speed dial numbers. Second, one of our phones has two buttons on the right lit up in Red like there are no...
If you mean the 10 number stored in 00-09, from the phone, pick up the handset (or press intercom) and dial *30 00-09 9 plus the number and # You'll hear a confirming tone. That stores the number. To dial, you press Autodial *00-09 and it dials the number.
What's under the buttons? Press PROG and the button and it will show what's there. Probably a digital station that isn't there. Press 2 and STORE and you'll clear the button.
Carl
Sep 28, 2011 | Panasonic KX-T7630 Corded Phone
How do you put a panasonic KX-T6730 on voicemail instantly if you need to leave the office early?
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
Dec 10, 2010 | Panasonic KX-T7630 Corded Phone
How do I get my panasonic kx-t7630 to ring more than 3 times before going to my voicemail?
If you've set call forwarding from the set, try dialin *713 and a 2 digit number from 00-99. It's the number of seconds before the call forward and a ring cycle is approximately 6 seconds, so start with 24 and go up from there.
There's another feature that will work against you, and that's the transfer recall time. It may be set to 20 seconds, so you will never forward before the recall timer. It's set on a systemwide basis.
Carl
Sep 16, 2010 | Panasonic KX-T7630 Corded Phone
New Voice Mail message
You received a message on the voicemail system provided by your telephone company. To hear the message, dial the voicemail number provided by your service provider (in many cases, this will be your own phone number), and follow the voice instructions for listening to your messages. You need to store the voicemail access # by pressing [MENU], [#] [3],[3],[1] on the handset. To access the voicemail, press [TALK], then softkey [VM]. Depending on your service provider, you may need to clear your voice mailbox to remove the notification.
Apr 12, 2010 | Panasonic KX-TGA101S Cordless Handset
Is there a built in answerphone in this model?
HI.
some info on your model.
Product Name : Panasonic KXT7630
Product Rating: 0 out of 5 (0 Rating ) Category: Home Telephone Brand: Panasonic Type: Digital corded handset Caller ID: Without Caller ID Ringtones: Standard ringtones Speakerphone: With speakerphone Number of handsets: 1 handset Messaging functions: No messaging supported
riz.
Mar 10, 2009 | Panasonic KX-T7630 Corded Phone
Voicemail box not set up
I have seen the same problem with some users (I look after the PABX) so I just go into the maintenance console and set up the foreward to the default voice mail number. Or you can try the following:
CALL FORWARDING HANDSET 1. Press the Speaker Phone Key on your handset 2. Then Press the FWD/DND Key 3. Then select the Forward type you desire - Key 2 - Immediate Key 5 - Busy/No Answer 4. Then dial the internal extension number (eg.444) or voicemail pilot (201) 4a. If forwarding to external number dial 0 then dial outside telephone number 5. Dial # then press the Speaker Phone key
Use the voice mail that is set for your system.
Hope this helps
Jan 08, 2009 | Panasonic KX-T7630 Corded Phone
Use 2 phones for one line??
take the 2nd handset to the working base unit and go to the menu, registration mode, and access handset registration. it must have the same password number as the first handset.Thank you. JER.
Feb 18, 2008 | Lands Phones
Kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Feb 11, 2008 | Panasonic KX-T7630 Corded Phone
Voicemail
Try going to http://www.reachcom.com/manuals/Panasonic_KXT7625_30_33_36.pdf where you can download the manual.
Cheers
AngelXena
Jan 10, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
162 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
