Question about Xerox XA3-17B 17" LCD Monitor
Screen is dark... you can see and interact with screen, but too dark too make out clearly, brightness and contrast set to highest level on osd! is there a backlight that can be repaired?
  • 32 Answers
This can mean either a bad backlight or inverter. The backlight is dificult to get to on most lcd screens, it is in the screen itself and trying to take apart the lcd's layers usually ends up a broken lcd. Luckily the problem is usually the inverter, which is cheaper and easier to replace.
Normally this is caused by the power inverter for the lcd. It is a small circuit board right below the lcd, that powers the backlight. If you take off the front bezel of the laptop you should be able to see it, it will have a 2 wire power cord coming out the one end, and another plug in on the other end with several wires.
9 times out of 10 the problem is just the inverter going out, check ebay for a replacment but make sure you get an identical model as the one you have, as they are very specific to each laptop. The inverter will have the part number written on it.
Posted on Sep 12, 2009
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Apr 17, 2016 | Princeton Digital VL173 Monitor
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
Dukane 7100HC The picture is dark. In a completely dark room. I recently replaced the bulb, but the picture was dark before I replaced the bulb. I've adjusted the brightness, but it just washes out the...
Turn the brightness up slightly and turn the contrast on the highest setting. There may also be settings to control wether your projectin on a wall or on a screen. Make sure these settings are correct to your setup.
Jan 25, 2011 | Dukane ImagePro 7100HC Multimedia...
How do I make screen adjustments - brightness, contrast, etc.?
Press the OSD (On Screen Display) button, to display the OSD menu. Use the LEFT/RIGHT and UP/DOWN buttons to cycle through the various settings. Press the OSD button to "select" one of the settings to be changed. Use the LEFT/RIGHT and UP/DOWN buttons to alter the setting. Press the OSD button to "accept" the new setting.
Oct 23, 2010 | AOC Monitor
Gateway FPD 1830 18.1 in. Flat Panel Problem
Usually in these cases the power supply would be the issue, but you say the OSD window shows up clearly, So the LCD panel is good and the Power Supply /inverter depending on which your FPD has.
FPD 1830 should have 3 boards(logic, Inverter, Power) otherwise just 2(logic, power)
If it is super dim, the problem is the inverter. Or the Power Supply if the inverter is embedded
Otherwise what your issue is the logic board, if you can swap out that part for a good one, Chances are for sure that you will have a spanking new FPD working.
I've worked with these a lot. Im working on one right now.
I hope this helps
Wish you luck
Victorsinferno45
Sep 11, 2008 | Gateway FPD 1830 18.1" Flat Panel LCD...
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Dark screen on all inputs, OSD clear
luminance is missing or the brightness. try to inspect the board at the back of the CRT see if there is an open resistor
Jan 14, 2007 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Computers & Internet Logo
246 people viewed this question
Top Xerox Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
JC Meredith
JC Meredith
Mark Magill
Mark Magill
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
