Question about Sony KP-61HS10 61" Rear Projection Television
Sony kp-61hs10 tv, has sound but picture goes black after 3 min.
Sony model kp-61hs10 tv, the sound stays on, but after 3 min. the picture goes black. the tv was bought in 2000. help!!
  • courtney Apr 22, 2009
    I have the same problem light blinks 5 times in front great sound but picture is gone in a few seconds can anyone help us and where is board c located can find other boards but not board c thanks for any and all help
  • thomaslinda May 02, 2009
    red light flashes for 5 times and picture every few seconds
  • 3 Answers
I just had the same problem. If your lucky it might be a free 5 minute fix. The five light flashes mean impropper current. I took the front grill off, then behind that is another black cover, I took that off and noticed the circuit boards COVERED in dust. I then took an air can duster and blew off all the dust... works like new. No more flashes and in an out picture. The collection of dust was interfereing with the electrical current.
Ben
Posted on Jun 22, 2009
  • i_laique_gro
    i_laique_gro Jan 08, 2012
    Same problem here and I tried that method, not working for me
SONY KP-61SH10, NO PICTURE, NO SOUND. THE STANDBY LIGHT CONTINUOUS BLANKS. CAN YOU TELL ME WHAT IS WRONG WITH TV.
there could be a number of things going on here.
first suspect, is the lamp. Unless you had other symptoms previously. More info from you would be key in helping you out further.
lamps do need to get replaced after around 4000 to 8000 hrs. 2-3 yrs.
Mar 29, 2010 | Sony KP-61HS10 61" Rear Projection...
The image leaves and the screen goes black.
Either the picture tubes are going, or they are dusty. Take apart the front grill and take off the black cut away behind the grill. Inspect the tubes and the circuit boards. If they are dusty blow them off with an air can duster. It might work and its free and takes 5 minutes.
Ben
Mar 23, 2009 | Sony KP-61HS10 61" Rear Projection...
Picture flashing on and off
Press Display / Info button on "TV original remote", such display will disappear.
Nov 17, 2008 | Sony KP-61HS10 61" Rear Projection...
Noise in sony tv
It needs service to clean inside. this click sound is spark of high volts, generated by H-V block, got carbonise dust ( black ) arround it.
Aug 12, 2008 | Sony KP-61HS10 61" Rear Projection...
Tv Problem
How many times does the light blink in between pauses? Also is your model the KP-61HS10 ? Please respond to this same post and I should be able to help you.
Jul 01, 2008 | Sony KP-61HS10 61" Rear Projection...
When t.v. is turned on, black picture and no sound.
Usually when the fuse blows its due to a component being shorted and if you increase the rating of the fuse you can cause other components in the circuit to blow. The pop you hear was most like a capacitor on the D board. The D board is no longer available from sony as its listed as discontinued. You will most likely have to have a qualified sony service tech trouble shoot the circuits on the D board to locate the short as it will be outside the scope of a do it yourself type of repair
May 16, 2008 | Sony KP-61HS10 61" Rear Projection...
Kp-61HS10
protective shutdown, being as sometimes you have audio leads me to believe its vertical deflection. Does the Led flash when it shuts down?
Mar 12, 2008 | Sony KP-61HS10 61" Rear Projection...
KP-61HS10
yes. go here
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Dec 20, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
356 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
