Viking DFUD042 Built-in Dishwasher
Problem for Viking DFUD042 Built-in Dishwasher
Small amount of water remaining in bottom basket
By jasavarese on Apr 15, 2009
when i turn dishwasher on and run through a full cycle there is water that is remaining in the basket at the bottom of dishwasher. Is this normal because I do not remember seeing water retention there before. Also since I noticed the water in bottom basket, the dishes have not been getting as clean as usual and there is somewhat of a sandy film on the dishes primarily on the top shelf. I am not sure if there is a clogged line somewhere or if this is an easy fix before I call for a repairman to come and spend loads of money. Please help!
Comments:
Apr 15, 2009
- we took that out and cleaned that screen as well.
Solution #1
posted on Apr 15, 2009
Somewhat Helpful)
MNfisherman
Rank: Wiz
Rating: 85%, 2702 votes
There is a screen in the drain that is plugged.
Comments:
Apr 15, 2009
- it this a new or older washer? some washer keep small amounts of water so you don't get sewer fumes coming out just like an elbow in a sink drain. Has this always been like this or did it just start happening?
On an older model, some state or local plumbing codes require the addition of a drain air gap between a built-in-dishwasher and the home drain system. If a drain is clogged, the drain air gap protects your dishwasher from water backing up into it. Check the drain air gap anytime your dishwasher isn't draining well. The drain air gap is usually located on top of the sink or countertop near the dishwasher. The air gap is an external plumbing device that is not part of your dishwasher. Follow the cleaning instructions provided by the manufacturer. With most types, you lift off the chrome cover. Unscrew the plastic cap. Then check for any soil build-up. Clean if necessary.
Was this helpful?
Yes
No
Popular Solutions for Viking DFUD042 Built-in
Questions and Unsolved Problems for Viking DFUD042 Built-in
Do you recommend Viking DFUD042 Built-in Dishwasher?
Answer
Answer
my dfud 042 will not start wash cycle. It makes a ticking sound two or three times and will not... (More)
Answer
need to locate part number pd120064 for a viking dfud042 dishwasher
Answer
was going to buy this dishwasher - but see alot of bad reviews - have you had many people... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Viking DFUD042 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
