Sony big screen television part
I am looking for a part for my Sony t.v. It is called a "green picture tube," (probably not the technical name), and the part number is 873365205. It is from model number KP-51HW40. Could anybody help me find this? It is not manufactured anymore, but I'm sure someone has a used one some where out there.
  • kwortman Sep 15, 2007
    My e-mail address is okie7311@yahoo.com. Troylove11, do you think I'll be able to find a part to fix this?
  • bajadietz Dec 03, 2007
    I also need the green tube,any one have one?Bajadietz@yahoo.com
    Genius:
  • 1,153 Answers
Give me an email address.
Posted on Sep 14, 2007
Picture turns green ,usually within 10 minutes of turning it on.It will sometimes go back to normal color but generally returns to green.This happened when the set was much newer and Sony replaced all...
Green Tube maybe trying to short out or you can try adjusting screen drive to the Green Tube by turning control down a notch, Sony had a bad run on these with alot of Bad Tubes.
Dec 08, 2009 | Sony KP-57HW40 57" Rear Projection...
I have the same problem(redish screen with no green at all)
Does Tube Light up? with TV on Look down into Tubes and see if picture is clear or you can bearly see picture or not at all Your Projection fliuld may need changing Ive seen where tubes are still lighting but No picture showing inside tube---- Bad Coolant Fuild Call Mats for fuild and for Tube if thats what it is Call Encompass 1-800-638-3328
Oct 05, 2009 | Panasonic PT-47WXC43 47" Rear Projection...
On our Sony KP-51WS510 projector television (with HD cable box) when we turn it on the screen goes green and the turns the cable box off and goes blank. Also I noticed the light on the front of the...
when it goes green, your green picture tube is shorting out, replaceing the green tube costs alot of money. these sony's had alot of bad tubes, the red and blue are probably going out too, it will cost alot to fix this, at least $500 even if you find good used picture tubes to put in it.
Sep 19, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 projection tv. Screen is green with curved lines
The green picture tube has an internal short. Happened a lot with that model. The tubes are no longer availible. But a reputable company called Video Display will rebuild the tube completely. But the tube must be pulled and shipped to them. Most repair shops would charge around $400 to $500 for the complete job.
Jul 09, 2009 | Sony KP-57WS500 57" Rear Projection...
Replaced red and green tubes
Good Day;
You may mixed the lenses. The lenses have an adjustment and there is a focus/screen block for focus adjustments.
Good Luck, big IRISH.
Sep 28, 2008 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57wv600 big screen
you will need to replace the Green CRT your model uses the sony # 873365201 CRT. The other site I work for just got a shipment of Sony and RCA CRTs(Tubes) in on friday. So you can get one at the following link these are brand new Tubes and they provide free shipping and free on line tech support with instant messageing in case you need help installing it. Heres the link.
http://servicemanuals.vstore.ca/
Jun 22, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue Screen
You have a bad blue picture tube. If you replace it the red and green will be weak and probably go sooner than you think. Everytime I had to replace a tube in a sony projo tv i had to replace all 3 picture tubes at the same time. It's very expensive if you don't have any type of warranty coverage.
C-Dog
Feb 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony big screen tv not playing picture after 5 minutes or so
You have a bad picture tube, or perhaps a picture tube drive problem.. To see what is bad, remove the front speaker grill under the screen in the front. Remove the screws that hold on the board that covers the front. Insidfe this set, WITH THE TV SET UNPLUGGED< Locate which one of the tubes is the blue one. Gently pull off the board from the end of the picture tube and swap it with the green tube right next to it. The green tube is always the middle tube. If the blue comes up again, then the blue tube is bad and you will most likely be better off to buy a new TV set. If the green comes up as the bright one, swap back the boards, call a tech and tell them there is a CRT driver board , or an RGB drive problem. This should not cost you an arm and a leg to get repaired. Good Luck, and let us know how you make out with the repair of this TV set.
Nov 11, 2007 | Sony KP-46WT500 46" Rear Projection...
Repair of my big sony screen tv
Sony tv red flashes
I hate to be the bearer of bad news, but you have a shorted red picture tube.It is not at all uncommon on sony rear projection. The gun shorts and the set identifies the problem and goes into shutdown. Usually there are diagonal lines in the picture before it shuts down. this is an unfortunate problem because this set delivers a great picture. The dealer cost of the tube is around $200. When the repair is complete your're probably looking at $400-$600. The only problem is that the green tube and the blue tube also have chance of having the same problem. It'a tough call . But from my experience , I have replaced the green tube and had the blue tube goe within a year. Scrivitron
Jun 21, 2007 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
