Question about Fusion FEW12PK Car Subwoofer
My subwoofer drained the battery to the car over night
I hooked up my sound system in my car and everything was working great. the next day i went to crank it and the battery was dead. I'm pretty sure that the amp sucked the battery dead. its hooked up to the system control, and when i checked it the previous night, the amp turned off when i cut the car off. any suggestions on wat the problem is?
  • 653 Answers
I am not sure how you have it hooked up, but the amp should be connected with heavy gauge wire to a relay that goes straight to the battery for the best current flow. The coil of the relay can be connected to the power output wire of the stereo (usually blue) or to a switched circuit. When the ignition is switched on or the stereo is turned on (depending on which you have it connected to) the power to the relay coil will connect the power from the battery to the amp. When you turn off the stereo or ignition, the power to the relay coil goes off and the spring breaks the circuit at the contactor. You can buy a relay at any auto parts place. Make sure you ground the amp near where the stereo is grounded or you will get a whine in the stereo from a "ground loop". Please don't forget to rate this solution.
Posted on Apr 15, 2009
2006 HYUNDAI TUCSON BATTERY DIES EVERY NIGHT!
try checking trunk light I serviced a lot of draining battery problems . I had one the other day the customer states every 4 days need jump start . 1st step ck charging system ok , starter draw was good . started to ck all drains all were normal . after dealing with this issue for a month i replaced his battery with a new one he never came back . calls me for reg service . A week cell in battery can pass the test . Hope this helps .
Mar 12, 2013 | Cars & Trucks
A couple of weeks ago I went out to start my Kia Sedona 08, however, found it was dead. I connected up battery to another car and jump started first time (and ran it for 30mins). It then started fine for...
Sounds like a battery to me. The cold doesnt drain the battery it just makes it more difficult to produce enough energy to crank the car. If the battery is weak already, the cold just makes it worse. Replace it and move on!
Dec 08, 2010 | Kia Sedona Cars & Trucks
I just bought a 2001 bmw 325ci the car had a rough idle when i drove it home and the check engine light came on. after about 10 min i took the car out the light went off i went to the gas station and...
Welcome to the world of BMW's. return the car to the seller. you got a bad one. You got an electrical short draining the battery. Bring a blank check and sign it over to the dealer. They're going to have to run through the entire electrical system to find the short. That work alone is worth more than the a used up 2001 325i.
Jun 07, 2010 | 2001 BMW 325
Two 10" Rockford Fosgate P1 subwoofers stopped making sound
Sounds like you've blown them.
When you were playing back to the friend, were you playing louder than usual?
Was the old box ported, and the new one sealed? The lack of ventilation may have caused the blow...
Jan 12, 2010 | JBL GT150 Car Subwoofer
1997 mpv mini van runs great. While traveling i drove from SC to Atl GA....parked and went into motel for evening...the next morning i had very difficult time getting it re started....Like it was not...
I think you should check your battery and alternator.If they both check good you may have a battery draw,something draining the battery over night.Check your doors make sure they are closing like they should.
Jul 28, 2009 | 1997 Mazda MPV
No sounds coming out of subwoofers
CHECK INSIDE UR SUBWOOFER BOX ...
Apr 11, 2009 | Pyle PLAM2300 Car Amp
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Fusion FEW12PK Car Subwoofer Logo
297 people viewed this question
Top Fusion Car Audio & Video Experts
Brandon Berry
Brandon Berry
Jose Velazquez
Jose Velazquez
Matthew Spark
Matthew Spark
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
