Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Model 61 Runs for 10-15 minutes then dies
Now, on to my problem. I have a Model 61 Husqvarna chainsaw. The saw starts and runs good for about 15 minutes and then it will just die. It will start back up but the performance is terrible and it stalls out after a few seconds. I have cleaned out the screen on the exhaust, replaced the fuel filter, spark plug, and put new gas in. None of these fixed the problem.
Are there any other areas that I should look at?
Any help would be greatly appreciated, the saw still has lots of life and I would hate to get rid of it.
  • srobideau Apr 15, 2009
    Thanks for the feedback I will try replacing the cap.
  • yankee42 Apr 19, 2009
    Yeah, same problem..found disintegrated fuel line that connects to the unit betwwen the carb and the cylinder. I'll know for sure in a couple days as soon as I figure out how to compress the ring on the piston and fit it to the cylinder, I'll be back in business.
    Problem Solver:
  • 5 Answers
Carb adjustments/also ratio of gas oil mixture
Posted on Apr 15, 2009
I took mine to the shop, got it back ($50!) said the gas was bad. Did the same thing, looked here, checked the gas gap and sure enough the vent hole was plugged. Works great now.
Posted on Feb 06, 2010
    Scholar:
  • 135 Answers
Sounds like to me that you may have a coil problem. I think it's running just long enough for it to run hot, then it screws up the electronics in the module. This module has a low rev side and a high rev side. Sometimes one or the other screws up.
I don't think it's the carburetor due to the fact that if there was a carb problem the engine wouldn't fire up so easily and it sure wouldn't run for 15 minutes before letting you know you have a problem. Either a carb runs well or it doesn't no such thing as good sometimes and bad at other times.
Again, have the coil checked.
Good luck
skidooer
Posted on Oct 03, 2009
Husqvarna 345 chainsaw cuts off when hot
It sounds like it may be getting lean at that point, and it could be something like a tank vent. When this happens, open the filler cap, close it, and see if the saw will start.
Another easy test is to fill the tank completely in the event that a small hole has formed in the fuel line inside the tank. I doubt that is the problem, but worth the time to check before moving on to other tests.
If that doesn't work, disassemble the carburetor and clean all passages with non flammable brake cleaner (carburetor cleaner can damage check valves and soft small engine components). Sometimes dirt can accumulate in places that affect how the diaphragm moves.
If none of this works, have a service shop evaluate the unit. Pressure and vacuum tests will reveal the culprit(s) and determine if the saw qualifies for service.
Mar 22, 2014 | Husqvarna Garden
Chainsaw cranks and runs but after minute or two it dies. will start again but dies when trying to throttle up
Check the fuel tank vent. Does the saw leak fuel when laying on its side.? Faulty vent can cause the saw to bog down when running
Nov 20, 2012 | Husqvarna Garden
Chainsaw stops running
When it starts to die slacken off the fuel cap enough to allow air into the tank, if it picks up again it is an issue with the fuel tank breather, if the breather is blocked it will create a vacume in the tank and stop fuel flow to the carb.
Apr 24, 2012 | Husqvarna Garden
I have a husqvarna 261 chainsaw. it will start half the time....the other half...no chance.i changed the spark plug.and im getting very good spark. took the carb apart and cleaned it. checked the plug when...
Hi, from what you have written I believe you have a faulty cdi unit. Carbys don't generally run perfectly intermittently. To test the cdi theory, close the sparkplug gap to approximately half normal gap. If the saw runs fine you have a faulty cdi, shorting ht lead or stop wire. Regards Phil.
Apr 26, 2011 | Husqvarna Garden
Saw runs fine for about 15 minutes,then the idle speeds up,then it dies,almost like it is flooding
Do aclean or overhaul of all fuel components.Change the spark plug or the coil aka=spark plug cable.But if your saw in lees the 2 yrs you need to follow the starting guide in order to avoid flooding.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 11, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
My Husqvarna 136 S/N 91VG/56 runs about 1/2 min. then dies. Start it again and it runs about 1min. and dies.
check air leaks between cilinder and carburator, if its ok- fine, check rebuid carburator.
Sep 16, 2010 | Husqvarna Chain Saw 20" Bar
Husq 350 runs with gas cap off but bogs and dies with cap tight
your gas cap is bad, it's not letting the air replace the fuel that is being sucked out. there for creating a vaccuum..... buy a new cap.
May 13, 2010 | Husqvarna 44 61 268 272k 225 Chainsaw Gas...
Husky 455 dies out at full throttle or under load
Your carb may be the issue but your ignition coil could be the culprit. Once they start going bad, they can act up intermittently or give various symptoms from day to day. The fact that your saw dies at full load or under load, probably means that when your saw gets hot or requires more spark, your coil is not able to provide it. Your carb is easy enough to clean out, you can take it all apart and clean all screens, etc....
I just replaced my coil due to the exact same symptoms and now my saw runs great. $60 off ebay and you can put it on in 15 minutes yourself. Check your carb first though
Apr 13, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Runs great for 30 sec. to 1 min. then dies slowly
Is it your chain saw Husqvarna 40?
Try carb adjustments H-3/4 turn ,L-2 turns and T a little higher
I presume that compression and ignition sistem is adequate for the engine to run.Good luck
mihai
Apr 04, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
1,203 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
