Question about Canon MV700 Mini DV Digital Camcorder
Canon MiniDV mv700i audio problem
I have a Canon MiniDV mv700i handycam. It works fine except in the playback mode, when the tape playing reaches the far end (like 5 min before finish) the audio goes on and off quite often. The audio goes blank for 1 or 2 seconds, then back on for few seconds and then off again. This happends on all tapes I play, so the tapes are definately not bad. Anyone any suggestions what's wrong with the camera ????
    Champion:
  • 217 Answers
A mechanical problem! The tension regulator belt is not well aligned, you need pro fix to do the alignment.
Posted on Sep 14, 2007
SOURCE:
Why is there an audio playback glitch?
Old or worn Audio Tape Head needs replacing,
Head Cleaning tapes are not the best for these, they can only be used so many times and they do rub tape carbon into the tape head, best thing to do is get an ear bud cleaner -"Cotton Buds" - and dip it into metho and give the tape head a light rub with it and ear bud, should do it...if still has issue then the tape audio head is had it, but rarely do they breakdown.
Apr 25, 2017 | Canon ZR300 Mini DV Digital Camcorder
I have a Canon mv700i and I'm now seeing horizontal lines on the screen in the playback mode (I'm trying to copy an older tape). I'm thinking the heads need a clean? Can I do this myself and if so how?
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 18, 2011 | Canon MV700i Mini DV Digital Camcorder
My canon camera seems to work fine in record mode. The LCD shows the video and the timestamp, and tape is moving. Yet in playback mode no matter what Tape I use (even if I know the tape has video on it)...
The playback head is dirty. Insert a brand new tape into the drive and perform a record, through the entire tape until it reaches the end. Then play a pre-recorded tape.
Nov 13, 2010 | Canon VIXIA HV30 DV Camcorder
Cannot view playback!!!!
First thing to determine is if your (Playback Mode) is set for Auto or Hi 8 / 8. Select VTR setting and then select Menu. Scroll to PB Mode and select Auto. Now try playback.
Oct 25, 2008 | Sony Handycam DCR-TRV820 Digital-8 Digital...
My sony handycam wont register the tape - only shows blue screen and wont show recordings.. HELP!
try a miniDV haed cleaning tape, the drum might be dirty, so no information is seen from the tape.
did you get a message " clean haeds on the screen??
Jun 29, 2008 | Sony Handycam DCR-HC30E Mini DV Digital...
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Mar 14, 2017 | JVC GRD650US DIGTL VIDCAM 32X ZOOM 16:9...
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon MV700 Mini DV Digital Camcorder Logo
61 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
