Question about Dryers
Kenmore elite home dyer won't heat up
Kenmore dryer won't heat up
Here's the tech manual, but you're going to need an ohm meter for testing. Here's the Tech manual https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203979621.pdf
Good luck.
Posted on May 02, 2009
My kenmore elite HE5 gas dyer won't dry properly. It will heat but not as well. It take along time to dry. Sometimes I have to dry my clothes twice before they will get completly dry. What could this...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 16, 2011 | Dryers
Can I use a 3 prong dryer cord on the Kenmore Elite Oasis dryer?
Most dyers are 220V. If the chord is connected to three terminals as most dyers have, then it would work just fine. Just be sure you connect the ground wire correctly.
Apr 08, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
HE3 Dryer not heating
check the thermal fuse and also check to make sure you have 220v at the outlet.
Jul 23, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
How do i light the pilot of my dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
I have a kenmore elite dryer for about 4 years and it will not heat up. Can you please help?
check breakers in panel make sure both are in the on possition(home elec. panel)....if thats not it replace both heating elements...they are located on the back usually held in by 2 screws in each one..youll find these at lowes or home depot
Nov 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
I have a kenmore elite he3 dyer it does everything it is supposed to but heat. pulled the front cover off unpluged the dyer and cleaned the inside, started the dryer again and the heating element came on...
A possible fix, which sounds completely absurd is to reset the circuit breaker. If you visually examine the breaker it will not appear to net resetting. This is because only half the breaker has been blown. You will not see this visibly and my husband thought I lost my mind and spent several hours troubleshooting before he would listen to my solution. We have only had to do this once in the six years of ownership. Hope this helps
Jan 18, 2009 | Kenmore 82822 Electric Dryer
My dryer wont stay on.
you have a bad microcomputer or as some calls it (even heat board) thats needs to be replaced / if you cant find one contact me with the complete model number from the sticker inside door area and i will see if i cant help you with one / larry
Dec 12, 2008 | Kenmore 63942 Dryer
Kenmore elite smartheat quitpak electric dyer
Hello talee725. the dryer has heat sensors located throughout. One at the air intake & exchaust of the heating element including the air exchaust of the drum. Disconnect the AC power, close the gas valve is gas powered, clean them and check the sensors with a DVM in the ohm scale for open ckt. They are usely round in shape with 2 wires connected. If test open call a local appliance parts/repair center for price and stock.
Nov 05, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
157 people viewed this question
Top Dryers Experts
