Question about Samsung Digimax S500 Digital Camera
Samsung digimax s500
The lens motor is/has stalled.where do i actually find one and who has actually repaired this with success.would like to do this repair myself, unless this truly is rocket science..........
Just took the whole thing apart. What a piece of junk lol
Posted on Feb 12, 2008
    Sergeant:
  • 274 Answers
It is very hard to do. It takes a "jewler's touch." I posted how do this for some one else. I'll find it and repost for you. My advice send it in for repair.
Posted on Sep 24, 2007
  • Jerry Hess Sep 24, 2007
    It's not rocklet science but very difficult without the tools at hand to hold the camera and the knowledge of where things go. So here goes...
    Yes, the lens/motor can be cleaned and repaired. But you need to almost completely disassemble the camera. If you are very good at mechanical repair on small items you can fix it. You need to be very patient. If you have big fingers like I do forget it. It's why I hired women to do my fine assembly work. You need the "jeweler's" touch if you know what I mean. The inside workings of the camera are really small and require a Magnifier with a light to see. Jewelers screw drivers and tweezers. Use Methanol to clean and not acetone. Alcohol works but Methanol is better. All the connectors are micros and irreplaceable if broken. The screw sizes (0-80 series and smaller)are mixed so care must be taken when replacing in the right location.
    If all this doesn't scare you then good luck.
    Remove the batteries. Remove the small screws around the case and pry open the camera with the lens down, LCD up. Careful not to damage the alum bracket with holds the LCD, remove the two or three screws that hold it down. VERY carefully lift the LCD and you will see the connector attaching a thin membrane lead to the main PCB. That connector is fragile! It has two very small tabs on each end of it but in fact it is one long piece. Push each end outward from the connector and membrane lead comes loose. Carefully wipe it clean and re-insert it when you reassemble the camera. Re-align the membrane carefully. Push the locking mechanism back in place when you reassemble the camera. Then you remove the main board careful you don't break any connectors or wire solder points. Clean the lens assembly using canned air. Taking the lens assembly out is "foolish". Don't do it. then reassemble the camera in reverse order. Before putting the outer case on you can power up your camera to see it you fixed it.
    If you didn't....it goes to the repair shop or the garbage can. It'll be cheaper to buy a new one.
SOURCE:
3yr old Samsung Digimax S500 takes very "horizontal lined-pixilated" photos
This is due to defective lens parts, So your camera require service (repair), Lens related parts need to be exchanged.
Rating the solution is highly appreciated....Good Luck
Mar 04, 2010 | Samsung Digimax S500 Digital Camera
Samsung digimax s500/cyber530 won't start with new batteries
I have a samsung digital camera digimax cyber 530 - just replaced batteries and camera wont start, i get 3 flashes from the green light screen nw comes on then goes off & the lens wont retrack back in the camera
Oct 20, 2009 | Cameras
Black screen
The issue is likely a bad lens assembly. Consumers wishing to repair this can check ebay for a replacement lens assembly, motor and sensor are usually included.
This happened to my Samsung s700 while I was mucking with it recently. It can happen when the lens meets severe resistance while trying to open, thus damaging the lens. The camera turns on and cannot tell precisely where the lens is, and subsequently the camera leaves the CCD imaging sensor turned off.
Replacement is easier than repair as lots of intricate parts are involved. However, the centermost ring will pop off with a little force, revealing four screws. The screws on the back side of the lens assembly are pretty obvious. Best of luck to anyone trying to fix this rather than replace it...
Apr 04, 2009 | Samsung Digimax S500 Digital Camera
Cracked LCd Sceen on a Samsung digimax S500
go to dealtree or 2nd turn on ebay and search for your camera with a stuck lens or focus problem the screen is mostly always good. if they say screen gives me an error or anything its good.
Nov 28, 2008 | Samsung Digimax S500 Digital Camera
Digimax S500
The lens stays in the outmost position although batteries are fully charged. This has happend twice. The first time I had a valid waranty so the problem was fixed for free. Now it has happend again and there seems to be no way to get the lens back into the camera. Also the display is totally black.
I guess I have taken about 500 pictures since the last repair. Not very much - even a cheap camera should last for longer than that.
Never Samsung again!!!
May 20, 2008 | Samsung Digimax S500 Digital Camera
Digimax samsung s500 beeps 3 times lens stuck wont stay on
Mine got stuck with lens out. The batteries were new so I never imagined it could be the batteries, but they were cheap ones so I recharged a pair of good ones and once I put tried them on it worked just fine again. Conclusion, the "new" cheap batteries had only enough energy to turn it on and then they couldn't give it enough energy to make it work anymore and that's why I couldn't retract the lens or even turn it off properly. So in your case, try using a couple of good and new batteries.
Dec 14, 2007 | Samsung Digimax S500 Digital Camera
Will not stay on
Lens motor stalled. Checkout the price of a repair at Samsung support
Sep 09, 2007 | Samsung Digimax S500 Digital Camera
My samsung s500 digimax isd problematic
The Zoom motor is shot probably because it has had a knock or dropped. This is not an economic repair option I feel Check Samsung customer support
Sep 22, 2006 | Samsung Digimax S500 Digital Camera
Samsung Digimax S500 Digital Camera Logo
346 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Anthony Ward
Anthony Ward
Are you a Samsung Camera Expert? Answer questions, earn points and help others
