Question about Gateway HD2201 22" LCD Monitor
Daytek lcd monitor model LM190
When plugged into computer and plugged into wall power outlet i can turn on but the screen stays dark. i can see the windows desktop on the lcd if i use a flashlight to look at the screen. help please and thanks to all.
  • 3 more comments
  • Tom Apr 25, 2009
    took item apart but i dont see any cracked or bulged caps or nothing that looks burned. i plugged lcd into another working monitor and the lights powered up so i know they work. what parts could be the problem?
  • Tom Apr 27, 2009
    im lost.... everything looks good. no popped caps or burnt areas on both boards? any thing else or is this the death of the lcd as i see it? thanks.
  • Tom May 14, 2009
    no pic attached? maybe send me one direct starmaxpc@yahoo.ca
  • Tom May 14, 2009
    nothing like that at all. could it be the two large yellow blocks (transformers not sure of the proper jargon?) on the inverter that are the problem?
  • Tom May 28, 2009
    took item to tech and inverter is the problem. anyone know where to find a replacement inverter?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Starmaxpc, Yeah, at least part of your switch-mode-power-supply is working! That's a good sign. Go visit these sites and see if you could do same. http://forums.pcper.com/showthread.php?t=452974 and pkrobot.freehostia.com/LCDRepair5.htm also try http://www.net/blog-entry/specialed/2008/12/31/how-to-fix-your-broken-lcd-monitor then get back to me if you intend to repair this DAYTEK LM190. Also there is a ton of other stuff that relates to failed power supplys in LCD monitors. Even YOUTUBE has a whole ton of stuff! Even disassembly videos of lcd monitors!
Bye for now. I'm louie12fix on fixya, or lmistyrel@ aol.com
Posted on Apr 15, 2009
  • 1 more comment
  • Lou Ebert Apr 25, 2009
    starmaxpc, louie12fix here. You have probably done more than most consumers would have done to try and find the source of your monitor problem! Have you tried to contact the Daytek people yet, to see if they have a swapout program? You send them your's+$40-$90 and they ship a refurbished same model back to you with new cold cathode fluorescent tubes+SMPS&INVERTER back to you. Also did you check the bottom(foil side/solder side) of the power supply and inverter board for cold solder joints/thermal fractures of component leads from top side mounted parts? You may need a good magnifing glass to help find them. Louie12fix
  • Lou Ebert May 14, 2009
    starmax, look for solder joints that look like this. See attached pic.
    louie12fix let me know what you find. Bye for now
    starmaxpc, I'll try to attach to this note a pic of cracked joint.
    louie
How do i factory reset my NEC LCD1712 Monitor?
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 22, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
Why going off after 5-10 min black screen
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
Jul 04, 2014 | Gateway 24" Widescreen Flat Panel TFT LCD...
On gateway w350i computer works HDMI works but LCD comes on but is only white screen please help
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
May 24, 2014 | Computers & Internet
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
Viewsonic VX2640W was running with the screensaver on,then suddenly went solid white. Turned off for thirty minutes then back on with same result. Unplugged from computer and turned on. Still turn
Feb 03, 2014 | ViewSonic VX2640w LCD Monitor
Screen scrambles
Jan 05, 2014 | ViewSonic VX900 19" LCD Monitor
ViewSonic monitor is starting to go dark
See if your monitor has a brightness control. The manual is here...
http://www.viewsonic.com/us/support/downloads/search_user_guides/
Nov 04, 2013 | ViewSonic VA1931WA LCD Monitor
Screen goes black or pixelates
Aug 18, 2013 | ViewSonic VX715 17" LCD Monitor
When I start the computer the Windows XP Logos light up on the Monitor (HP w1907) when the computer starts the Logo disappears and the monitor goes to sleep
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition.
Monitor Mike
Aug 19, 2010 | HP vs19 (Silver) 19" LCD Monitor
Screen rolls
I'm writing to you on a screen that is rolling and sometimes flickering right now. I've tried 3 different screens on the same outlet, and they all have the same problem.
1. If you have any speakers near your monitor, try moving them away, this might help because they might not be shielded enough.
2. Try another screen, if the problem persists, it may be your power outlet.
3. If you don't want to spend money on a new screen, spend some time looking for a 3-prong grounding adapter.
I used the 3-prong grounding adapter, those little adapters that plug into the wall using 2 prongs, and then you can plug a 3 prong appliance into them on the other site, and it helped make the rolls not appear as often, and not as dark.
I think it is something with my power or the plug I am using.
Hope this may have helped a tiny bit
Oct 25, 2007 | Acer AL1916W 19" LCD Monitor
Gateway HD2201 22" LCD Monitor Logo
598 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
