Question about Micro Electronics WinBook Z1 PC Notebook
Finding the cmos battery in my winbook z1 - Micro Electronics WinBook Z1 PC Notebook
Contacted microcenter technical support
Posted on Apr 15, 2009
Winbook. Why doesn't it turn on or charge?
It probably fails to turn on because the battery is drained. If it won't charge, first check the charger. Make sure it is working and putting out power. If it is working, then it could be the charging port in the Winbook, because it should power up with the charger plugged in regardless of the battery state.
Nov 21, 2015 | Computers & Internet
Winbook users manual
Have a look at this Site.
http://pcsupport.about.com/od/supportw/p/winbook.htm
You should find it there.
Otherwise let me know which Winbook you use.
Best Regards
Gue.
Mar 02, 2015 | Computers & Internet
Winbook laptop wont power up, could it be a security thing
First you state Desktop then Laptop ?
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in themon that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty
computers need all power and data to travel through every working device and to finish its cycle
so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cycle
make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets.
some Motherboards Cmos batteries are soldered in.
Mar 10, 2014 | Winbook Corporation PowerSpec MCE 410 PC...
My winbook 330 will not turn on. I have the power
You could try removing all memory, CMOS battery and try to clear BIOS by holding down power button for 30 seconds.
Re-install all and try to restart.
Sound like unit may have run hot and burnt the Processor.
Sep 03, 2009 | Computers & Internet
I have a WinBook XL Laptop that will not Power up,start up, switch on.
Check your power adapter if it is still working. Try taking out the battery and plugin the power adapter and see if its gonna turn on.
Jun 02, 2009 | Winbook Corporation PowerSpec MCE 410 PC...
How do I FIND a repair manual so I CAN upgrade system memory
You most likely have purchased the wrong memory for this. It should be a 200 pin SOdimm DDR.
Crucial.com lists the specifications here: http://www.crucial.com/store/listparts.aspx?model=WinBook%20V415.
I hope that helps. Good luck!
-jodair
Apr 06, 2009 | Winbook Corporation X530 (575001) PC...
Laptop CMOS battery
This is for Winbook WinBest 233MMX may be good for other Winbooks
Had trouble booting then just quit booting altogether...
For a quick fix that won't require soldering....
Replace the cmos battery2.gif. If it is more than 7 years old, it will most likely be weak or dead.
Remove the keyboard by sliding the KB toward you and lift the top up and slide out, Remove KB ribbon cable2.gif from connector by pulling on the plastic tab, remove the 4pin KB power connector. Then remove bottom screws and separate the case.
Locate the 3V battery, Pry the top tab of the 3v battery off the welded ends with a small needlenose, Pry the battery off the mini board, bend battery tabs so the new non-tabbed battery will be squeezing the new battery for contact, + is up!, add a piece of electrical tape to secure it from sliding. Replace bottom case and screws and then re-attach keyboard2.gif ribbon cable and 4 wire power connector. Re-boot and reset cmos ( CTRL-ALT-S ) on boot. Set your time. You must set the boot sequence to C:. It will then auto boot to C: WALLA! WIN98!
Mar 18, 2009 | Micro Electronics WinBook J1 Notebook
32'' Winbook Lcd Tv bad main board
eBay: Find WINBOOK LCD TV CONTROLLER BOARD 6870C-0060F in the Electronics
I located this board at anewparts on ebay, hope this helps you also
"Q"
'Til the Wheels Fall Off!!
Dec 26, 2008 | Televison & Video
Remote code for Insignia DVD/VCR combo and Winbook 32LCD TV
I have a Onkyo HT-S70 surround sound amplifier with a remote control. I am trying to find out what the code is to operate the Insignia BlueRay DVD player from the remote control?.
Oct 05, 2007 | Zenith ZN-501S Remote Control
Micro Electronics WinBook Z1 PC Notebook Logo
150 people viewed this question
Top Micro Electronics Computers & Internet Experts
Dennis Maeder
RSole
Masood Rasool
Level 1 Expert
Are you a Micro Electronics Computer and Internet Expert? Answer questions, earn points and help others
