Question about Harman Kardon HK695 Computer Speakers
Im tryin to hook my speakers to my computer
I have a harman kahrdon 695-01 speaker that i am trying to hook to my computer but have no clue to what i am doing do you know how i can get a instruction to it
  • 11,896 Answers
I don't have a picture to show you but will tell you the easiest way.
There is a cable that has headphone jack on one end and two rca jacks on other end. The headphone jack goes to computer and the rca jacks go to your stereos input jacks. Then turn on your stereo and set it to the input setting. That is all there is to it.
Posted on Apr 14, 2009
Is it possible to install aux 3,5 mm plugg?
Probably not, but you can buy a 3.5 mm.-to-RCA adapter cable to hook up a device with RCA (L/R) AUDIO OUT jacks (and no 3.5 mm. headphone jacks) to your Harman Kardon speakers which, I assume, have only 3.5 mm. LINE/AUX IN jacks (1 or 2).
Jul 15, 2014 | Harman Kardon Harmon Kardon SoundStick II...
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
Will Harman Kardon HK 206 speakers work with Dell Inspiration 560 with Windows 7 and if so how do you hook them up and install
since they are stereo they should have not issue. just connect the 3.5mm jack to your output port typically the green audio jack.
Jun 27, 2011 | Harman Kardon HK206 Computer Speakers
I have a harman/kardon class 2 transformer model# 661520oo3ct. It was with my computer equipment but not hooked up. I don't remember what it was for. what uses does it have?
hi,
it comes with ur desktop speaker harman kardon hk 206. it is a 12v 1A dc power supply. u can use it in any equipment which needs that power rating. only thing to remember is, check the polarity of both before connecting.
ok
Dec 17, 2010 | Harman Kardon HK206 Computer Speakers
Multi amp hook-up
honestly i dont think those to amps will push cvxs no matter how you wire them up.
the rms on the 200 should be used to push a door speaker.
the 800watt should deff just be hooked to 1 cvx but still wont max it out.
Dec 25, 2008 | Rockford Fosgate Punch 301M Car Audio...
Speakers
Hook on speakers to the right jack.
Most of times it is the Green Jack you must plug in the speaker. See for the speaker icon below the jack, that should give you the clue...
Hope this helps...
Jun 21, 2008 | Computers & Internet
Speaker setup
This is a hard problem when one is not looking at the speaker. But let me give you a little help if I can.
Try pluging the subwoofer into the speaker port of the Pc
Make sure your pc is turn of.
2) I believe the subwoofer has four jacks at the back.
3) Plug each of the speaker into the jack that says speaker
4)Now, if you are confuse of the in and out, on the subwoofer I understand. I believe you should be from out of the subwoofer to the in of the speaker. again, I cannot see at the back of you subwoofer.Only speaker from exprience.when you are done, turn your pc back on and turn the speaker on. making sure the volum is turn low.
good luck
Jun 18, 2008 | Harman Kardon Audio Players & Recorders
Speakers not listed in sound output options
I would try un-installing the driver/ application that controls the speakers and re-instaling.
Jan 24, 2008 | Harman Kardon SoundSticks Computer...
Compatible?
Have you tried sending out the signal from a TV to an amplifier then to the speakers? Can you give me a specific set-up on everything you are using, including cables?
Aug 17, 2007 | Harman Kardon Creature II Computer...
Harman Kardon HK695 Computer Speakers Logo
619 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
