Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Coating film on screen has a 'hole' after cleaning
Hi, I went to clean the Plasma screen the other morning as there were finger marks on it. I noticed a particularly dense area of marking on the top right of the screen. I thought nothing of it and proceeded to clean the screen as usual with a plasma cleaner I bought and had used before. I was horrified to see the area 'melt' and a film seemed to be peeling off the screen. I stopped wiping but there is now a 'hole' in the coating of the screen. Is there anything I can do? My husband suggested just cleaning the whole thing off, thanks for any suggestions. Pat
    Novelist:
  • 159 Answers
Not panic!
I'm reading it and i did it again, to give you the advise. the plasma screen is glass that's sure, then:
The actual problem is really simple. because i remember my last jobs with plasma and this is actually a film protector the manufacture use when the part is not installed yet in the actual tv set.
  • Your husband is right. (but the plastic is like one or two inches inside the frame and is hold it by the frame and the screws attaching the display.
  • if the tv is under manufacture's warranty have them clean their mistake. call them and make them peel it off for you.
  • but if there is not any waranty on it. then the solution is as you can figure it out . Have some one who can actually take all parts apart and finally peel off this film and put anything back together as is now. to let the tv cristal clear at the front.
Posted on Apr 15, 2009
Dishes not getting clean... AND white powder residue. Tried all of the clean rinse additives, vinegar rinse, and CLR rinse... then I noticed that the white coating on the heating element is wearing off...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
LG Plasma 5 years old has 4cm black line from top to bottom of screen
Just mark where the line is, then dismantle it. You'll find a connector & film at the same spot as the line (bottom of screen) . On this film is SMD resistors, resolder them VERY carefully, as these can go dry joint. Clean connectors
Assemble
Oct 30, 2008 | Televison & Video
My Nokia 5230's volume suddenly went very low. Either I've made a call or receive a call, the volume when answering the phone is very low. I've increased the handset volume to maximum but it's still low....
Please see if there is dirt clogging on the earpiece that would have reduced the volume from the speaker. If so use a pin and soft cotton to clean or you must open the cover and use a brush and air jet.
Secondly the possible weakness of the speaker/earpiece or the weakness of the low power output amplifier is another possibility.
Feb 18, 2011 | Nokia 5230 Cell Phone
Screen damage from Panasonic Viera TV
Hi
There is a solution. If you brought this to my shop I would replace the film (depending upon availability). Absolute worst case is replacing the screen (costly). Of course this is my shop, you'll need to take it to a reputable repair person. Sorry
Mar 29, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Cleaned glass with glass cleaning cloth and coating coming off
The coatings cannot be replaced once damaged unless new lenses are fitted. Strictly speaking, they can, but it will cost far more than buying new lenses.
Without the coatings your binoculars will work just fine but under some lighting conditions you may notice a lack of image contrast and perhaps some lens flare. Under other lighting conditions a total lack of lens coatings can actually improve the image as more light can pass through the optics to your eyes. It's not a fault which usually merits replacing the binoculars.
Just use the cleaning cloth sparingly in future on any coated lenses: dust should just be blown off but small amounts make no practical difference and careful handling should prevent finger marks on the glass surfaces. Salt spray and errant finger marks should be removed using a lightly dampened lens cloth: de-ionised water with about 5% alcohol is ideal.
Oct 18, 2009 | West Marine Optics
Why is the film automatically rewinding around 15 shots instead of the end of the 24 shot roll? The batteries are fresh.
the roll sensor is not reading the silver code on the film roll.
Open the camera when you have no film in it.
Clean the film roll slot where the "fingers" are.
These fingers touch the case of the film roll to determine the film type, which includes the number of exposures. You nmay have to "adjust" the fingers so that they make good contact with the film roll case.
Look at different rolls of film, notice the silver blocks are different. If the roll has a "dent" on it, it can't be sensed correctly.
Hope this helps!
Sep 15, 2009 | Canon Sure Shot Classic 120 35mm Point and...
How do I find top dead center on a 1999 gmc 5.7
On the first cylinder (first closes one of right side). After plug is removed, turn motor until piston is at very top of cylinder.
Jun 22, 2009 | GMC Sierra 2500 Cars & Trucks
Tint on plasma tv screen has come off in patches! Help!
unfortunately the process cant be reversed. the glass filter have (which is in plastic material) has to be replaced by a new one. it is recommended to clean the screen using micro-cloth only.
Mar 19, 2009 | Panasonic Televison & Video
REFLECTION COATING
the ammonia in the glass cleaner ate protective coating. The only way to fix it is to replace the glass. $$$$$
Apr 09, 2007 | Sony KE-P42M1 42 in. Plasma Television
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
599 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
