Cd drive won't stay closed - Computers & Internet
  • 1 more comment
  • cmarconi1152 Apr 14, 2009
    Hp Pavilion entertainment pc Vista WINDOWS
  • cmarconi1152 Apr 15, 2009
    OK, I disabled the E drive and now the doors stays closed. I will take it in and see if I just need a new one. The confusing thing is, it will hold a disk and run, but when their in no disk in the drive the door pops open. Thanks gymowner
  • Nasser Abou Agena
    Nasser Abou Agena May 11, 2010
    what kind of computer you using and what is the model and what windows are you using?
  • 679 Answers
When you click on my computer on your desktop icon. And you can pick the various drives contained in the machine, you are probablly looking at the D or E driveon possiblly F, being that vista uses the C drive as the place to store your system files in case of a crash. But if you select the drive that shows the eject, command, it should open or close the door of the drive. If it is not doing that then we either need a device driver for that drive. Or if it is not responding to any commands, go into the device manager and uninstall it then reboot. if after this still nothing, then just replace the drive, you can get a new one that't a 26 0r 28x drive for abot twenty to thirty dollars. Since a tech get's onefifty an hour it's just not worth your time and money to fix a possibly burned out part that is that cheap. I hope this helps you find which it is, if it got fied there is no more to do for that kind of price difference, just pick up the latest model, and consider it an upgrade
Posted on Apr 15, 2009
  • 227 Answers
Make sure you inserting the disc in correctly, and make sure your drive reads that type of disc.
Hitachi ax-m71 cd door won't stay closed. Unable
if it opens back up when you close it the drawer mechanism is probably out of alignment. Most players have a slot on the bottom of the drawer that a pin must slide in. Look under the drawer and see if there is a pin sticking up that maybe should be in that slot.
Jul 09, 2013 | Audio Players & Recorders
CD drive won't close
If the CD tray won't close then it's probably a mechanical issue with the drive and needs to be replaced.
May 07, 2013 | Dell Inspiron 530 Desktop Computer
The cd drawer won't stay closed
the cd drawer will probably use infra-red to sense when the drawer is open or closed or maybe just a gear mechanism, either way these must be clean, I'd take it apart and lean it all with cotton buds and isopropyl alcohol
Feb 07, 2013 | Audio Players & Recorders
Cd draw opens on power up and won't play a cd keeps opening after closing
This unit needs replaced it has seen better days sorry. The only thing you can try is shut off all power to the PC then unplug the PC and that cd drive from the rear of it. let the PC boot all the way up so you see your desk top. Shut it all the way down un plug PC hook back up the wires on the back of the CD player let it boot back up see if this stops it.Remember to rate my solution this is how i earn my achievements also testimonial Thanks much in advance.
Apr 22, 2012 | Dell Dimension 3000® Pentium® 4...
My Dell Inspiron CD Drive Won't Stay Shut
Wow. Power off the laptop then turn it over. Look for the one screw that holds the cd drive. It will have a circular icon on it. Remove the screw and then pull the cd drive out. Then put it back in and replace the screw. Hopefully all it needed was to be reseated.
Mar 20, 2012 | Computers & Internet
Door won't stay closed
There may be something stuck inside the drive. If you feel you have sufficient skill, I would remove the drive and shake it around to see if you can get something to fall out. Other wise replace it with a new drive or take it to a repair shop.
Mar 19, 2012 | Samsung SD 616E (729507925578) Internal...
Cd drive pop open
this is a common problem with cd drives
Aug 24, 2009 | Toshiba Satellite Pro S300M-S2403 Laptop
CD drive stays open
Dirty lense? Best to get a new one. It maybe the motor aswell. CD drives are normally about £10
Jul 14, 2009 | Samsung (SC-152) Internal 52x CD-ROM Drive
DVD Drive door stays open
>One solution is to TAKE A SMALL PIN AND RESET YOUR DRIVE BY POKING THE PIN INTO THE HOLE BELOW THE DOOR..
If this doesnt solve....
You need to necessarily replace the drive..
Jul 07, 2009 | Samsung SC 152 Internal 52x CD-ROM Drive
My cd/dvd opens then closes
> I've already replaced it once
Well, I've seen CD-drives that would re-open, when you try to close them -- it is _falsely_ detecting a "jam" as the tray is closing, and then just re-opens the tray, rather than "forcing" itself to close.
Replacing the CD-drive is the only way to fix that type of "false-positive" jam-detection conditions.
But, since you've done that, either you were unlucky-enough that the replacement drive was also "defective", or, you have a computer-virus on your computer that is maliciously issuing commands to the CD to "open-the-tray".
Sep 20, 2007 | Compaq (224130-001) Internal 4x CD-ROM...
Computers & Internet Logo
555 people viewed this question
David Payne
David Payne
