Whirlpool ACQ122XK Air Conditioner
Problem for Whirlpool ACQ122XK Air Conditioner
After turning the unit on, it clicks to start, but then clicks right back off...
By sand13go619 on Sep 13, 2007
I just installed a used Whirlpool ACQ122XK airconditioner, that has been stored for about a year. Anyways, I turned the unit on before I inserted it into its housing unit and it worked just fine. Then I inserted it into the housing unit and ran it for about 10 minutes and it ran fine, but the front radiator looking piece was sort of grimy, so I turned it off and vacuumed it, even though the bottom of it was sort of wet. I did not bend any of the aluminum pieces or anything, but now it won't turn on. When I turn the unit on, the lights come on and it sounds like it is going to start blowing, but then it clicks, behind the "power square" with the on/off switch and the cool/fan speeds, and the blower turns back off. Then about 30 seconds-1 minute, it clicks again, like if the blower is going to come back on, but then it clicks again and turns off. I have tried to unplug it and let it set for 3-5 minutes and try it again, but it does the same thing over. Do I need a new unit or is this a minor problem that can be fixed? Or even a solution, that I can possibly try, that might make it work? Thank you for any help that I can get!!!
Solution #1
posted on Oct 24, 2007
Not Rated)
BIKER T
Rank: Guru  Whirlpool Expert
Rating: 86%, 240 votes
once you switch the unit off mid cycle, it needs time to equalise before it will switch on again.  otherwise check the cap.to start the compressor.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool ACQ122XK Air
Questions and Unsolved Problems for Whirlpool ACQ122XK Air
Do you recommend Whirlpool ACQ122XK Air Conditioner?
Answer
Answer
My comfort Zone II has stopped displaying the third zone. What could be the problem?
Answer
My dehumidifier runs but does not extract any water.
Answer
The heat pump was covered in ice and the unit was squealing. i turned it off and the ice started... (More)
Answer
my central ac unit never shuts off, the fan blows all the time (the compressor comes on and cools... (More)
Answer
How do we program this unit. I can get it to tuurn on, then it shuts off after one second,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool ACQ122XK Air...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
