Question about Whirlpool LGR5636L Gas Dryer
Motor stops would like to remove shell to clean around
Motor wont spin need /to remove shell/ think something is wrapped around motor
  • 490 Answers
The front of the machine comes off look at the bottom for a couple of screws remove the front and you can see inside
Posted on Apr 14, 2009
Hoover carpet cleaner brushes wont spin
First i would be checking for a mechanical restriction stopping the brushes from spinning like hair or similar wrapped around the brushes and jamming them, if all is clear it could be a belt broken or slipping, a stripped gear or an electrical fault, depends on what type of drive system the brushes on your particular vacuume cleaner uses. Hope this is helpful.
Aug 17, 2017 | Hoover Vacuums
A ge top load washer first began by making a buzzing noise instead of spinning. Now it doesn't spin as fast as before or just wont spin. Jeans wrapped around the agitator shouldn't damage the spin?
the agitator spins with the tub so clothes wrapped around the agitator will have no effect on the spin other than a balance problem
The hum and failure to start spinning may be attributed to a failed (failing ) start run capacitor or program board not moving on properly
As the start /run capacitor is for the motor and if it start the wash cycle ok but after that cycle ( around 30-40 minutes) it may be too hot to restart the motor for the spin
I suggest that a technician be called in to get a proper diagnosis and a quote
Apr 14, 2016 | GE Washing Machines
Lg DLE3777W wont start
if the motor is running and the drum is not spinning check the belt that wraps around the drum and motor. may have broke or just slipped off
Jun 21, 2012 | LG DLE2512W Electric Dryer
Hey, I have a Whirlpool Hotpoint electric dryer that is broken. The drum will not spin. I can hear the motor engage like its trying to spin. It will do this about three times (start/stop cycle) then...
remove belt from motor so there is no drag on motor or pulley,then spin motor shaft and pulley by hand,it should spin freely and coast to a stop,if it is hard to spin,the bearings are dried out and normally its new motor time,you can try removing motor and soaking bearings in a solvent and re-oiling,but that usually doesn't do it
Jan 16, 2010 | Washing Machines
Very noisy after styrofoam bag was sucked up by accident. Motor itself is extremely noisy.
you could have damaged the brush assembly or there could be something else wrapped around it take it apart and clean the brush and see if that wont stop the noise
Aug 23, 2009 | Vacuums
Shakes violently in the spin cycle
hi...
the reason it shakes violently is because
1)Most noisesfrom a washing machine occur during the spin cycle. If you hear loudthumping during the spin, the load of clothes may have becomeunbalanced. Stop the washer and redistribute the clothes, then re-startit. Repeat these steps if necessary.
or else the other reason may be
2) If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch Ifyour washer has a selector switch on the control panel, make sure thebutton for your selection is pressed all the way in, or set properly.
Clutch assembly ManyGE®/Hotpoint® washers use a clutch and an automatic shift lever. Thisassembly is quite complicated. If there's a problem with it, youprobably should contact a qualified appliance repair technician.
Drive motor manywashing machines have multiple-speed drive motors. Though it'suncommon, the drive motor may work fine on one speed but not onanother. If the drive motor has failed on one speed, you need toreplace the entire motor.
On something like this you will need to
remove the washer wrap toinspect the suspension springs & base assembly. Be sure the shippingpins have been removed. The tub should float freely.
I think my solution would have helped you...rate for me if it is been useful.....thank you for using fixya....
Jul 20, 2009 | Admiral Washing Machines
New Roomba 560 beep twice, ask to clean brushes, but no dirt
your roomba is thinking that you need to clean the brushes. if too much load it put on your brush motor--the unit will think that something is wrapped around the brush and slowing down the motor. if you have cleaned your brush and are sure that is not the problem; you need to look for anything else that could be slowing down the brush/motor. If this is inconclusive you need to put your roomba into diagnostic mode by following the procedures in the link below http://swiftracer.com/index.php?myPage=RoombaDiagnosticMode.php
Jun 13, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
No power
It sounds like you have something wrapped around the spool, (where the string is), that is keeping it from spinning.
If that's not the problem, then it is the carburetor. It will need to be cleaned or it will need a new carb. kit. How old is it?
Let me know if you need cleaning tips.
Jim
Jun 11, 2009 | Garden
Helpp
If you have removed the drive belt from the rear pulley and the inner spin basket does not spin freely, you either have a drum bearing seized up on you, or something binding between the spin basket (stainless steel tub) and the outer tub shell. First, you need to reach inside the wash tub with the washer empty. Place the palm of your hand at the 12 o'clock position and push straight up. There shouldn't be any play in the spin basket. If you can feel the basket wobble up and down, you have either a bearing problem, or a spin basket support (spider arm) broken on the back of the spin basket. If there is no play at all, you probably have something caught. Small articles of clothing can sometimes get pulled between the tubs and usually ends up around the support shaft in the rear. This will obstruct the basket from spinning freely and could eventually cause damage to the drive motor, spin basket and/or tub bearings. You can use the instructions for replacing a rear tub bearing that I have posted under my Tip and Tricks for instructions on how to disassemble and inspect the tub. The bearing may not be bad, but you still need to check to see if anything is binding the spin basket against the tub shell and inspect the spin basket supports. Unfortunately, you have to disassemble the washer to be able to inspect any of these items I mention. I hope this helps you.
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LGR5636L Gas Dryer Logo
51 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
