Question about Zyxel Prestige 334W Wireless Router (WYP334WZYXEL)
Conflict with partner network detected.
I'm trying to connect to VPN, but I keep getting an error message that says "Conflict with partner network detected." I don't know the login or password to my router either.
Default password is "1234".
You need to set up a subnet that is different than the subnet your vpn is connecting to.
For instance, default on the 334is: 192.168.1.0/24 SO the router will have an IP of 192.168.1.1. Because of the error, the other network has that same subnet (192.168.1.0/24)
And that router probably has the same IP as your router (192.168.1.1)
So one of the networks needs to change. You could just change the IP on one Network to: 192.168.2.0/24 and the IP of the router to 192.168.2.1.
I would change them both though, so this doesnt happen again.
Posted on May 13, 2009
Frequent VPN connection drop on my wifi
If you can't connect via the Internet to your workplace network from home (or another location), check the items in this list:
  • Make sure that you typed the virtual private network (VPN) server name exactly as provided by your network administrator.
  • You must have an active Internet connection for a VPN connection to work.
  • If your modem is external, make sure that the modem power is turned on.
  • Contact your network administrator to make sure that you have the appropriate connection and domain permissions on the remote access server.
  • This could be a certificate problem. For assistance, contact your network administrator.
  • A VPN connection won't work with an active Winsock proxy client. Contact your network administrator to make sure the Winsock proxy client is not enabled.
  • If you know the IP address (for example: 131.107.10.25) of a website, type that address in the address bar of your web browser and press Enter. If this works, there is probably a Domain Name System (DNS) resolution problem. For assistance, contact your network administrator.
  • If you have special software that's required or installed by your workplace, it could be part of the problem. For assistance, contact your network administrator.
  • If you know the IP address (for example: 131.107.10.25) of your VPN server, type that address for the VPN connection, and then press Enter. If this works, there is probably a DNS resolution problem. For assistance, contact your network administrator.
  • There could be a problem with the server you're trying to connect to. For assistance, contact your network administrator.
If you try to connect with a VPN connection and you see a message that says "The local computer does not support encryption" and has the error code 741, it's possible that the encryption that your computer uses doesn't match the encryption used by the VPN server. To change the encryption settings so that your computer uses the recommended setting of 3DES, follow these steps:
  1. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
  2. Right-click the VPN connection, and then click Properties.
  3. Click the Security tab.
  4. Under Data encryption, select Maximum strength encryption (disconnect if server declines), and then click OK.
  5. Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
  6. Click the VPN connection, and then click Connect to try connecting again.
Apr 21, 2013 | Belkin Surf N300 Wireless N Router
"Windows has detected an IP address conflict"
If all looks good try right clicking on network status icon in sys tray and use repair. A more advance option would be to use ipconfig from the command prompt.
Start > Run (search in Win 7) > type ipconfig /release. Then ipconfig /renew. ipconfig ? will show you all the options. Good luck.
Sep 20, 2012 | Computers & Internet
Every time i go to oovoo it keep getting this error Error 101 (net::ERR_CONNECTION_RESET): Unknown error.
DON'T USE GOOGLE CHROME ITS FULL OF TROJANS!!! WINDOWS DEFENDER ON MY MACHINE DETECTED IT!!!! TRY FIREFOX!!!! HOPE HELPS :D
Feb 15, 2010 | Google Chrome
Login errors occur when trying to use new networks
log in errors problems comes on the solution is the net work ip address is not matched plz find and given correct ip address
Jun 14, 2009 | Check Point VPN-1 Accelerator Card...
Can't login to voice mail.
Multiple login error will clear up if you reboot your phone system with voicemail.
Jun 01, 2009 | Avaya Lucent Partner 616 Phone
Cisco VPN Client Error
Hello
Try to switch off the Cisco VPN Stateful firewall.
Apr 19, 2009 | Computers & Internet
I cant login into my space my school has it blocked
Multiple solutions:
-Log into the computer as an administrator. The admin account possibly does not have the same policy.
-Install VPN software on the computer at school, also install VPN software on your home computer. Login to your home computer through the VPN software at school and browse the myspace pages.
-Long shot but give it a try, change it back if it doesn't work -
Open Internet explorer, Select tools from the menu list, select Internet Options from the bottom of the drop down list, Select the Connections Tab, Click the LAN Settings box torwards the bottom. Deselect "use proxy settings", select "Automatically detect settings". Restart IE. If you get nothing, change it back.
-Get myspace IM on your cell phone
Apr 14, 2009 | MySpace Social Network
Vpn connection
That error means it was unable to connect. Can't find vpn server or security was wrong. Are you running a firewall? If so, open port 1723 and try again or shut it down while testing.
Mar 12, 2009 | U.S. Robotics (9107) Router (USR9107A)
Error message
The VPN you want to connect to has not given you permission to connect. Check with the administrator on the other end.
Oct 29, 2007 | Computers & Internet
Open Questions:
Computers & Internet Logo
134 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
