Question about Garden
Won't Start I have replaced the battery, solenoid, ignition, air filter, spark plugs, and starter and cannot get the mower to crank. When I first switched out the starter (Which was the last thing replaced) it tried for the first two cranks and now it does nothing. The solenoid pops real loud when I try to start it and that is the only sound I get out of it. I get 11 volts to one side of the solenoid but don't even get one volt from the side that the starter is hooked up to. I sanded down the metal behind the solenoid and got nothing. I tried jumping a wire from the battery straight to the starter and still nothing. If anyone could help thanks.
    Problem Solver:
  • 5 Answers
Unbolt the starter, and try it, to see if it turns over. make sure it is grounded or it won't turn. next turn the engine over, to make sure it isn't locked up, if everything looks ok then put the starter back on, check the voltage at the battery, a fully charged battery will read up to 13 volts, check your wires from the battery to the solenoid. make sure the eyes on the ends of the cables are making good contact. If the wires get hot you need to make new ones, this normally means it isn't making a good connection, and low voltage going into you're starter will make a spark in the windings and ruin the starter. It would be a good idea to use a little heavier wire than the facctory did . If you get power to the solenoid and when you hold the key in start psition you dont have any power on the other side of it,and you can hear it clicking, you will need a new solenoid, which would mean this was the cause of the problem. If everything is ok put your meter on the battery and try to start it. if it drops below 10 volts you might not have a high enough cranking amps battery.
Posted on May 23, 2009
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Why won't my riding lawn mower crank over?
Hi if you have got it cranking remove the plug and check for a spark the plug must be earthed to do this if you have a spark it must be fuel pore a small amount in top of carb make sure ign is switch on hope this helps.Ron.
Jun 20, 2014 | Craftsman 420cc 30 6-Speed Rear Engine...
My d100 will not start
Check for good , strong spark. Take spark plug out and ground the outer core of the plug to the engine. Hold the plug with a pair of insulated pliers. Have someone crank the engine while you observe for a good strong blue spark. If the spark looks nice and bluish, then next would be to clean the carburetor. I suggest trying a "quick clean before taking the carburetor bowl off. Take spray carburetor cleaner and spray inside the carb throat with the air cleaner off. Also take about 1/2 can/bottle of fuel line injection cleaner and put it in the gas tank. Then try starting the mower. May sure the gas in the tank is fresh.
Jun 20, 2014 | John Deere Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Jeep 06 libary will not start ,starter good and battary good what the probable
Do you mean it cranks but won't start?
Check for spark at a spark plug wire. If you have spark, it's probably not the ignition, but a fuel issue. Do you hear the pump come on briefly when key is turned to on? You may need to stand by the gas tank with the cap off, while someone turns the key on. The pump should hum or whirr for about 2 seconds to prime the fuel system. Then it will shut off until car is cranked over. If the pump and the ignition is working, check fuel pressure.
If you had no spark, it could be the coil, or crank position sensor, or...well, you would have to diagnose the ignition system.
If the problem is not cranking over, check all connections at starter and battery for a clean tight connection. Check for power at the starter solenoid when key is held in crank position. If power there, the solenoid must be bad. If no power the circuit from ignition switch to the starter solenoid has a problem ( like the starter relay or the neutral safety switch).
Good luck.
May 26, 2012 | 2005 Jeep Liberty
I HAVE A POULAN MOWER TRACTOR MODEL HD12538B THAT WILL NOT CRANK. I HAVE JUMPED THE BATTERY WITH THE CAR, REPLACED THE SOLENOID AND THE IGNITION SWITCH. i HAVE ALSO JUMPED THE STARTER AND IT WILL CRANK...
Try replacing your spark plugs. Make sure its getting gas. Make sure your air filter is nice and clean. Check your fuel filter. and if all those fail try replacing your coil.
Feb 07, 2011 | Poulan Garden
Wont start turns over but no start
1 Inspect Battery Battery Discharged or Faulty. 2 Inspect Battery Cable Corroded, Broken, Shorted or Poorly Connected Battery Cable. 3 Inspect Fuel Filter Clogged or Dirty Fuel Filter. 3 Inspect Distributor Cap Distributor Cap Cracked or Burned. 5 Inspect Coil - Ignition Faulty Ignition Coil. 6 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 7 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s). 8 Inspect Starter Starter Motor Faulty. 9 Inspect Fuel Pump Low Fuel Pressure. 10 Inspect Solenoid Switch Faulty Starter Solenoid Switch. 11 Inspect Relay - Fuel Pumpat Faulty Fuel Pump Relay. 12 Inspect Fuel Injector Pressure Regulator Faulty Fuel Injector Pressure Regulator. 13 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch. 14 Inspect Starter Drive Faulty Starter Drive. 15 Inspect Fuel Injector Dirty or Worn Fuel Injectors. 16 Inspect Fuel Pump Strainer Clogged or Dirty Fuel Pump Strainerat. 17 Inspect Engine Control Computer Incorrect Operating Information Being Delivered and Sent From The EEC. 18 Inspect Fuel Tank Fuel Tank Empty. 19 Inspect Carburetor Carburetor Flooded or Faulty Choke. 20 Inspect Distributor Worn, Loose, or Incorrectly Installed Distributor.
Jul 02, 2009 | 1997 Ford F250 SuperCab
WONT START
Not so many reasons she won't start. 4-Strokes are Simple!
Here they are:
Motor:
Fuel Tank-> Fuel Line-> Fuel Filter-> Carb-> Intake (Valve)-> Piston-> Exhaust (Valve)-> Muffler
Carb (Old Style):
Fuel Side:
Fuel Bowl-> Float-> Needle Seat-> Fuel Ports (Venturi)
Air Side:
Air Filter-> Carb Air Intake-> Butterflies (2)
(Clean 'em ALL!)
Hardware (Motor):
Rotor (Magnets)-> Magneto (Ignition Coil)-> Spark Plug Wire-> Spark Plug-> Cylinder Head (Spark Plug Ground)
Ignition:
Kill Switches (Seat, Clutch, etc.)-> Spark Plug/Ignition Coil-> Ground
Key Ignition-> Battery->Starter/Generator
If one of those fail.......= Non-Starting 4-Stroke!
Fixes-
Fuel:
You are either getting too much, or too little. Too much = Carb.
Too little = Carb. Therefore, tear down the Carb (COMPLETELY-Careful!) and clean it up.
Electrical:
Grounding out the System (Kill Switches)
Battery-> Ignition-> Starter.
Magneto->Plug Wire->Plug (Check 'em all!)
May 28, 2009 | Mtd Garden
Garden Logo
500 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
