Question about Dishwashers
Does this model fully drain?
We just moved into our apartment and we've noticed that there remains about an inch of water in the interior drain area. The landlord insists that this is normal for this model which "does not fully drain." The handy man did work on it a bit. During the first few days, whenever I put in the liquid soap, water and bubbles would pour out from under the door. So far it does not clog up, but I wonder if this unit is really fixed.
  • 423 Answers
Switch immediately to a Brand Name Dishwasher powder (like Electrosol or Cascade.)  Avoid gels, tablets and never use a dish soap that is meant for washing dishes in a sink.  This will solve the "bubbles" problem.
Yes, dishwashers do maintain some level of water inside to keep the pump seals/gaskets from drying out or seizing. As long as the water down there is clear and has no odor, you and your apartment's dishwasher is fine.
OK?  Post back with any more questions.
Posted on Apr 15, 2009
Stops in cycle, not sure if its when rinsing? I notice it stops and an error code of OE ?
This error code OE means the tub is not fully drained 10 minutes after the drain pump is turned on.This is possibly due to a clogged/kinked drain hose or the drain filter is blocked. Make sure the drain hose is clear then open the filter door located at the bottom left front of the machine. Drain the remaining water from the tub through the emergency drain hose located in the filter door area. Once completely drained, turn the knob counterclockwise then pull out and clean the filter. Reach in the pump impeller area and turn it with your finger. Replace the drain pump if the filter is clear and the impeller is broken or restricted and cannot be freed.
Jun 18, 2011 | LG WM0642H Front Load
Hi, We just moved into
On the bottom of the rubber seal, there is a drain hole. Check to see if it is clogged and clear it out if it has an obstruction.
Jan 01, 2011 | Washing Machines
Dirty dishes on Maytag 24 inch dishwasher, model no MDBH940AWS, Dishes have caked on gunk on the glasses after washing. The gunk is usually at the bottom of a glass (which is in the dishwasher upside...
This dishwasher has a circular filter path under the bottom plate - 6 screws - that can become filled inside with debris - you can remove it and wash it out with a garden hose.. Paul
Nov 20, 2010 | Maytag 24 in. MDBH940AWS Built-in...
Sound like water in the dash board slashing around. Took it to the dealership to be checked and they said I had a drain hose that was cloged, they cleaned out the hose but not the water, what can I do that...
If the drain hose was cleared the water should have drained off. It sounds like the Condensation drain is still partially or fully clogged and not allowing the water to drain off. The only way to get into the area of the condensation drain, other than through the drain hose, is to open up the Coil area on the interior of the vehicle. When they attempted to clear the drain they most likely used a wire and ran it up the hose to clear it. If the drain hose is actually clear you might be able to drain it a little further by elevating the rear of the vehicle.
Jul 22, 2010 | 2005 Pontiac Grand Prix
Interior water dripping on passenger side
I have researched this problem online and have noticed many people have the same issue with this car. I have made a complaint with the Better Business Bureau and suggest you do the same.
May 24, 2010 | 2003 Toyota Corolla
My VW GTI has an interior water leak. Can't find it, but the rear passenger side is full of water?
Two areas to check. The sunroof has several drains that can clog. Open the sunroof and look in the four corners. You will see small holes. Try flushing water down each one with like a cooking baster or spray bottle. If that won't clear a clog use a long wire but with a rounded end. You could cut rubber parts if the end was sharp. The second area is in the door panel area. Each door should have drains in the bottom. If they are clogged it will overflow into the interior. Also if that door has been serviced and the moisture barrier was not reinstalled correctly you will get some water leaking inside.
Feb 08, 2010 | 2003 Volkswagen GTI
Same problem. 2-3 inches of water left in the dishwasher at end.
Inspect for plugged drain screen. Sometimes you have to take apart the bottom area for access...
Sep 18, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For...
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Apr 19, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Dishwashers Logo
133 people viewed this question
Top Dishwashers Experts
