Question about Kenmore 73952 / 73954 / 73959 Top Freezer Refrigerator
Ge refriderator 3yrs old stopped working
It is a standard fridge, freezer on top. stopped working, no light. not a breaker tripped, power at outlet ok. Any tips where to check first? are there any particular problems with this brand and type?
  • 291 Answers
Need a model # check for power starting at end of power cord where attaches to refrigertor
Posted on Sep 15, 2007
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
REFRIGERATOR KEEPS TRIPPING THE GFCI OUTLET
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
Nov 30, 2017 | Jenn-Air Refrigerators
Refrigerator wouldn't cool
Hi!!
Is there any light coming on on the board?? If not, ckeck for Tripped Breaker or blown fuse, if OK, check propane tank.
Take the grill under the fridge or to the left of it, (4 screws), that's where the refrigerator's power outlet is, check for 120v or use an extension cord and plug fridge to it. If fridge works, check for short or loose wire from outlet to breaker panel..
Don't forget to rate this post. Good Luck!!
May 23, 2010 | Refrigerators
STOPPED COOLING AND FREEZING ,ONLY HAD IT SIX MOTHS,BRAND NEW
Hi!!
Check for:
Power to the Unit, (is the light inside fridge coming on?) If not, check for, tripped breaker, outlet and power cord.
Temp.controls, (it is very easy to inadvertedly move controls while cleaning unit) the one for the fridge should be about half way and the one for the freezer should be about one third. (Wait 24 hrs. between checking and adjusting temp settings.)
Don't forget to rate this post, keep me posted if need aditional assistance, Good Luck.
May 08, 2010 | Whirlpool GS6NBEXRL Side by Side...
My lg fridge just stopped working no lights or power, the receptacle works and no breakers tripped
I have a similar manual that shows just what you are up against. How about the power cord itself? Is it ok?
FRENCH DOOR REPAIR MANUAL
Feb 16, 2010 | LG LFC20760ST Stainless Steel Bottom...
No power to fridge. power to house ok, circuit breaker to fridge not tripped. what to do?
plug something else into outlet and see if it works your outlet/ wiring maybe bad if it works your power cord for fridge maybe bad have a short in it if outlet or cord is bad call eletrictian
Jul 07, 2009 | Sub-Zero Refrigerators
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Refrigerator compressor not working
unplug the fridge,remove the electrical cover on the compressor to see if any wires are burnt off.you may have a defective start relay,wire off or compressor seized,that age not cost wise to replace compressor
Apr 09, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Refridge stopped working after a power surge
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Apr 03, 2009 | Refrigerators
Kenmore 73952 / 73954 / 73959 Top Freezer Refrigerator Logo
79 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
