Question about NetGear RP614 Router
Doesn't work bought a netgear router from ebay. do i need driver software before it will work?
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 25, 2009
NetGear Wireless Router and NewGear WG111 Adapter
I imagine you bought the WG111 Kit. It could but throught the Router and/or the adapter. Uninstall all netgear software and drivers. Unplug the adapter. Reboot machine. Plug the adapter in and install the software drives. Basically your starting over. This will take the quess work out of trying to repair what was lost. After reinstalling go to this web page to configure the SSID,IP and adapter. http://kbserver.netgear.com/kb_web_files/N101179.asp
Jun 27, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Arris tm502g doesn't recognize Netgear n600
Did you run the driver CD for the Netgear N600 ? That is the first place I would look. Or it is possible that your Netgear N600 is not working properly. There are some very inexpensive small USB dongles that do work very well, I would try that as well. They run in the less than $10.00 range at places like Ebay or Amazon.
Apr 18, 2017 | Computers & Internet
Netgear WGR614
First thing I did with my Netgear is this.
Plug in the dsl/cable modem to the PC directly. Then install the driver on the cd. If you are one of the unlucky types like I was, the router didn't come with a cd. Try going to Netgers page see if they have a driver. Most are basically auto install. Try this before you check the netgear site though. Plug in the cable/dsl modem to the router and the pc to the router. Resstart everything. This includes the modem, router and pc. When it pops back up, try seeing if that works. if not, try opening up Internet explorer. Type this in to the url. 192.168.1.1 or 192.168.1.0
That should bring up the netgear setup page for the router. If it ask for a password, the password on mine was
username - admin
password - password
It has an auto configure tab so click on that and that should automatically take care of everything for you. Let me know what happens!
Feb 27, 2008 | Computers & Internet
How to install?
Go to netgear.com and in the support section you can download drivers and instruction manuals
Feb 12, 2008 | NetGear Super G WGT624SC Router...
Drivers for Netgear WPN 824 V2
First I would reset the Router to Factor Default
Press the reset button on the back until the test light blinks. This takes about 10 seconds. (To avoid accidental resets, the small button is recessed. Use a pen or paperclip to access it.)
Release the button.
Wait for the router to reboot.
Set your computer IP address to 192.168.1.3
connect your computer to the router, open a webpage and enter 192.168.1.1 you should get the username and password screen
Default username: admin    password: password
or could be 1234 but should be the first.
Oct 11, 2007 | NetGear RangeMax WPN824 Router
NetGear RP614 Router Logo
48 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
