Question about Samsung SGH-d807 Cellular Phone
Signal Amplifier doesn't work
The signal amplifier doesn't work properly, how would I go about fixing it? And if I have to replace it, how much would it cost me?
    Brigadier General:
  • 7,752 Answers
Re: Signal Amplifier doesn't work
That is very hard to say you would have to take the phone to a mobile service center or a mobile tech close to you.
Posted on Jan 29, 2008
0 characters
3 Points
I have absolutly no signal on my 6210i.....please help
try this step.
1. reset to factory default but first backup all your contact and important data, all application also ill removed.
2.if still not working it because your Power Amplifier Chip need to be replaced.
Mar 04, 2011 | Nokia 6210 Navigator Cell Phone
Mic problem i change mic but it not working
The fault can be the mic input amplifier which is not working to increment the signal to the desired level to be fed into the circuit.
So you will need to trace the signal path if you are confirmed with the mic connection and type.
It is fault in the mother board.
Jan 21, 2011 | Nokia 2690 Cell Phone
Signal drop
you need to replace the power amplifier(pa) mounted on the top part of the phones board.
Sep 22, 2010 | Nokia 1100
My phone not getting signal properly when a signal low area.some time even is signal available,cant take call to phone.
thats a hardware problem, your RF amplifier should be weak. it is responsible for amplifying and mentaining the signal on your phone. you should therefore take it to a service point so that they check it anf if possible replace it.
May 10, 2010 | Nokia 6300 Cellular Phone
Signal problem
reheat or change antenna switch and power amplifier one at a time..if it doesn't work reheat hagar, ccont, cobba...
Jul 10, 2009 | Nokia 3315 Cellular Phone
Nokia 3100 network signals disappear
You must change PA(Power Amplifier) IC on your phone.5-6second signal than gone is a sign of PA IC not work any more.You know that PA is an IC where phone use to transmit.I hope it help.
Jun 15, 2009 | Nokia 3100
No signal
3100 Network Problem
Apr 16, 2008 | Nokia 3100
No signal
Your phone is shorted'
fastly heat' and battery broke' automatically
P.A. Problem, change the Power Amplifier to fix your phone,
skilled technician can do...
Dec 17, 2007 | Nokia 6610
Network problem for 3100 nokia
if handset is not able to recieve the signal means (no signal bar on the screen means)go to phone settings and search manaully even you didnt get any operators VCTCXO is the problem by replacing it you can solve this .
if you get the operators by manuall search and you couldnt access , problem with UEM or by PA(power amplifier)
Nov 02, 2007 | Nokia 3100
Phone suddenly turned off...
You need an expert one to open your phone, during your conversation the signal components is in heavy duty, one of this is the signal power amplifier ( P.A ) the source of power is from power IC ( UEM ) grounded P.A sometimes kills the phone and need to replace it, if not work, the UEM is already busted replaced it, before all of this try to reformat first.
May 14, 2007 | Nokia 6600
Samsung SGH-d807 Cellular Phone Logo
23 people viewed this question
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
