Question about Panasonic KX-TG2382B Cordless Phone
Panasonic KX-TG2258 with E1 ERROR CODE
My Panasonic KX-TG2258 is now non functional. All lights are blinking continuously with E1 Error Code. Can anyone help?
David
  • Anonymous May 13, 2009
    hello my diears
    plise help me.
    Panasonic KX-TG2258 with E1 ERROR CODE" problem
I was having that problem after cleaning the base and handset. It seems to resolve itself simply by disconnecting the power supply and possibly the phone input line for several hours. I reconnected my phone and it works again.
Posted on Aug 12, 2010
  • aguguica
    aguguica Feb 07, 2014
    Dear, I have the same problem. I disconnected it but the problem persists.
Yellow light constantly flashes on all handsets
Yellow light constantly blinks on top of all the cordless phones
www.faqqq.com/.../yellow-light-constantly-blinks-on-top-of-all-the-cord...
Question Product: Panasonic KX-TG5432 Digital Dual Cordless Telephone Question Details: Yellow light constantly blinks on top of all the cordless phones The.
Panasonic KX-TGP550 Normal Status Lights
www.statuslights.com/panasonic/panasonic-kx-tgp550.html
Red (Rapidly Flashing), The Base Unit is paging handsets. (KX-TGP-500 only). Amber(Solid), The Base Unit's IP address may conflict with the IP addresses of ..
Jan 16, 2016 | Panasonic KX-TG7641M KX TG7641M KXTG7641M...
Manual telefono panasonic kx-tg2258 en que pagina puedo conseguir el manual en español
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Jan 12, 2011 | Panasonic KX-TG2208B Cordless Phone...
All lights on my phone base blinks at the same time continually
I suggest that you unplug the phone's power from the wall for about two minutes then power back up.
May 30, 2009 | Panasonic KX-TG2740 Cordless Phone
Phnoe and Answering System Inoperative - E1 flashing
I read about this, and while you were gone, if your power went out, try unplugging the batteries from the back of both phones for a few minutes & put them back in..I hope this helps!
Jan 22, 2008 | Panasonic KX-TG2357 Cordless Phone
PANASONIC KX-TG2258 E3 ERROR CODE
This method worked for me!! you guys should try this.
i've copy this review from amazon.
by Kane Doerfler
"After a brief power outage from a thunder storm, I also experienced an e3/lights blinking error. I unplugged the phone and plugged it back in several times to no avail. After doing this a couple of times unsuccessfully, I hit the "STOP" button on the base immediately after plugging it in (before it completed booting up to show the "e3 message")and it reset itself and now works fine (or as well as it did prior to the e3). Try it before tossing yours in the garbage"
thanks to Kane. I saved my phone~!!
Nov 17, 2007 | Panasonic KX TG2258S Cordless Phone
A bank of blinking leds??
The blinking LEDs means it need to have it's ID reprogrammed. Press the Program button and then the station number (Station 1 or 2 or 3 etc) to store the setting.
Nov 14, 2007 | Panasonic KX T3281W Corded Phone...
Panasonic KX-TG2382B Cordless Phone Logo
1,173 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
