Question about Samsung HL-S5679W 56" HDTV
No image, no melody, fan message
Two days ago the "check fan no. 3" message came up before it turn on fully. yeasterday the unit clicked on, then off, then on and stayed on with a black screen for about a minute, then turned off. all three lights on power button lite up. i have had previous problems with it in the past and had the input connections replace and the last tech said he replaced the "motherboard"
  • 116 Answers
Fan #3 is stalling and needs replacement.
Posted on Apr 15, 2009
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
Message Alert Repetition
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Printer TX550W has message "A printer error has occurred. Turn off and then on. See your documentation".
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps.
1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following.
1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges.
If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
Nov 23, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My TR3624 (12 deep cycle 6V batteries - 1 year old and heavily used) doesn't want to fully charge my batteries. It will charge to 100% at 70A and shut off nicely and go to the "3 bars mode"....
U indicate that the batteries have been heavily used. Well, they do wear out and heavy usage will accelerate their demise. When batteries start to go, they do not charge as well and continue to charge less and less.
Best bet is to check them all after they have been "fully" charged to weed out the offending unit(s).
Apr 14, 2017 | Xantrex Technology Trace Series Inverter /...
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
Kenmore 665.6061200 over range microwave. Problem started a few days ago with a clicking sound from the RH side of the unit (seemingly behind the control panel), about 3 clicks per second for about 3-4...
The most likely cause of the clicking sound is the power relay that is connected to the microwaves PCB (circuit board) that turns the magnetron on and off. If starting to fail it may result in multiple clicks, then once fully failed, your microwave would simply not heat anything (as the high voltage components would not be getting power).
Unless you have a strength in electronics and repair, and understand the lethal dangers involved in working on a microwave, even one that is unplugged, this problem will likely need to be repaired by a qualified service centre.
Depending on the microwave design and the technician the whole relay circuit board may need to be replaced making this repair vary from relatively inexpensive to more expensive.
Oct 21, 2010 | Microwave Ovens
ACER Aspire 5100 powers down at will
When you turn the laptop on hit f8 until the menu comes up, try use the last good known configuration. If that does not work tap f8 goto safe mode and then to system restore and restore it to an earlier time. Let me know if it works.
Apr 15, 2009 | Acer Aspire 5100 Notebook
Connection problems
what is the master reset for lg vx8500
Nov 08, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S5679W 56" HDTV Logo
144 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
