Question about Tablets & eReaders
I can not get my dragon touch tablet model mid7138
I can not get my dragon touch tablet model mid7138 to get past the android screen
brimknows
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
  • 345 Answers
SOURCE: have a 10 magni tablet model SYTAB10ST screen shows sorry! the process android.process.acore has stopped unexpectedly please try again . it has a force close tab on screen but the error still pop up t
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
Posted on Dec 20, 2012
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
amandaellett
  • 13 Answers
SOURCE: Have the dragon touch 10.1" hd tablet everything in Chinese how do I switch it to the English language
If is itunes compatible just hook up to computer running: tunes/ if not can do reset by pressing volume up key, home key, and power key holding till reset screen appears.
Posted on Mar 01, 2013
  • 142 Answers
SOURCE: Pin no. set in error on this tablet now we can't access the tablet at all because we ca't get past the pin no. Please help or advise how to restore to factor settings.
Do you mean that the PIN of the SIM card is locked?
The PIN is needed to access the SIM card.
If you remove the SIM card the tablet will not ask for a PIN.
You do not need to change anything in the tablet.
(If you would insert your SIM card in a phone, the same would happen when you launch the phone.)
I hope this helps.
Posted on May 11, 2014
Testimonial: "The tablet does not have a sim card. Just a basic tablet with a number password instead of a pattern. many thanks"
I have Dragon touch tablet my screen is crackedhow much does it cost to have screen repared
Replacement Touch Screen Digitizer Glass Panel for Dragon Touch ...
https://www.amazon.ca/Replacement-Screen-Digitizer-Dragon.../dp/B0168RMIAS
Rating: 5 - ‎2 reviews
Replacement Touch Screen Digitizer Glass Panel for Dragon Touch X10 10 inch Octa Core Android Tablet PC: Amazon.ca: Electronics.
Tutorial to fix broken Dragon Touch X10 digitizer screen; tips, tricks ...
? 15:01
https://www.youtube.com/watch?v=wrAnFICL0nI Sep 16, 2016 - Uploaded by The_Ging
This video provides a step-by-step walkthrough to teach you how to replace the touch screen digitizer panel on ...
Touch Screen Replacement for Dragon Touch A1X 10.1'' Quad Core ...
www.actablet.com/touch-screen-replacement-for-dragon-touch-a1x-101-quad-core-ta... Replacement Capacitive TouchScreen Digitizer Glass Panel for Dragon Touch A1X / A1X Pro / A1X Plus 10.1'' Quad Core Android Tablet PC. ... 1 x Dragon Touch A1X (A1X Plus, A1X Pro) 10.1'' Quad Core Tablet Capacitive Touch Screen Digitizer Glass Panel Replacement. ... Tell us what you think ...
Replacement Touch Screen for Dragon Touch 7'' Dual Core Y88 ...
www.actablet.com/replacement-touch-screen-for-dragon-touch-7-dual-core-y88-andr... Actablet.com : Replacement Touch Screen for Dragon Touch 7'' Dual Core Y88 Android Tablet PC - Buy China Wholesale Replacement Touch Screen Digitizer Glass Panel for Dragon Touch 7'' Dual Core Y88 Android Tablet PC + Free Shipping worldwide! Features: Brand new, original touch panel for Dragon Touch 7'' ...
Touch Screen Replacement for Dragon Touch Y88X 7'' Quad Core ...
www.actablet.com/touch-screen-replacement-for-dragon-touch-y88x-7-quad-core-tab... Actablet.com : Touch Screen Replacement for Dragon Touch Y88X 7'' Quad Core Tablet PC - Free Shipping Worldwide! Replacement Capacitive TouchScreen Digitizer Glass Panel for 7 Inch HD Dragon Touch Y88X 7'' Quad Core 1024x600 Android Tablet PC Features: Brand new, original touch panel for Dragon Touch ...
Replacement Touch Screen Digitizer Glass Panel for 7" Dragon Touch ...
https://www.amazon.com/Replacement-Screen...Dragon-Tablet/dp/B010KESGOW Rating: 4 - ‎37 reviews
Amazon.com: Replacement Touch Screen Digitizer Glass Panel for 7" Dragon Touch Y88 Y88x Q88 Tablet Pc: Computers & Accessories.
Dragon Touch M10X Screen Replacement - iFixit
https://www.ifixit.com/Guide/Dragon+Touch+M10X++Screen+Replacement/62143 Dragon Touch M10X Screen Replacement: If the screen on your Dragon Touch M10X is damaged and needs replacing this guide will allow step by step instructions on how to replace the screen. ... Step 1 Screen. Remove the two screws from the top of the tablet as shown in the figure using a J0 philips head bit. Edit.
Mar 20, 2018 | Dragon Touch Tablets & eReaders
My dragon touch 7 inch tablet doesnt start up. the screen goes directly to white and it wont go from there
There are a couple things that could cause that. Does it still have sound? If you can hear the sound continue, it is likely caused by either damage underneath the screen, moisture inside it, heat/sun damage, etc.
Jul 22, 2016 | TabletExpress Dragon Touch 7 Black Dual...
What are all the connections for on the side of my dragon touch tablet?
download a manual, it will provide you with all the answers you require
Oct 10, 2015 | Dragon Touch Touch R10 10.1 Google Android...
Instructions for Dragon Touch A93 9"
Just use Google to find your answers. Use "Android" in your questions, not "Dragon Touch", since most Android devices work the same and Dragon Touch hasn't published much info.
(Most of the Cookie Cutter tablets don't come with instructions.)
Sample questions for Google:
"How to zoom Android Camera"
"How to configure Android WiFi"
"How to upload Android pictures to PC"
Mar 03, 2015 | Dragon Touch Tablets & eReaders
Dragon Touch Android tablet. How can I replace a broken power button?
I bearly got my dragon touch and then my power button broke?
Jan 26, 2014 | Tablets & eReaders
Dragon touch MID7138
how do i get my dragon touch talbet to turn on compeltely. it will not go pass the android page.
Mar 30, 2013 | Sylvania Sytabex7-2 7" Tablet Express Plus...
Tablets & eReaders Logo
296 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
