I am Having problem restoring my dell 2400
I am trying to restore a dell dimension 2400 but it will not boot automatically from the hdd or cd rom drive..i keep getting an error press f1 to reboot or f2 for setup utility..i did that already and i made sure the pc could boot from both CD ROM drive and HDD..still nothing happens..it keps getting the same error..so please anyone...help..any help is greatly appreaciated...ohh and one more thing..i already tried formatting the hdd on another dell..same..dimension 2400 and then putting it back on the other dell i am having trouble with..and..guess what..i keep getting the same error..i already tried f-12 at boot up and still the same and i also went went into the bios and made sure i could boot only from my CD Rom...and there is no system restore in the bios..plzz help..thanks in advance.
  • 2 more comments
  • rosas_jesse Apr 16, 2009
    i already made sure everything is connected correctly..i still have the problem..
  • ultimitloozr May 11, 2010
    What is the actual error message you are getting? It should be giving you more information than press f1 to reboot or f2 for setup.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Do you have the recovery disks for that computer?
  • Dick
    Dick May 11, 2010
    Rosas, you already tried everything you can do on your own. Take the computer to a technician or get a new one.
  • 227 Answers
Well you may have a bad mother board or IDE port to which the HDD is connected. If the CD is connected to the same IDE channel as the HDD, move it to IDE1 which is the second IDE channel. If it then recognizes your CD, IDE0 is bad and you need to replace your board. Let me know how things are connected inside the computer.
Posted on Apr 14, 2009
2 Suggested Answers
byron21
  • 151 Answers
SOURCE: Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Posted on Sep 24, 2009
Hi, I have a Dell dimension 2400 desktop. I plugged in a (wiped securely) hard drive. After it loaded the DELL LOGO BIOS, it shows a blank screen with a " dash -" on the top right corner. I...
try tapping the F12 key over and over when you see the DELL Screen to bring you to the boot menu....with your CD in choose to boot from the CD and it should allow you to run the OS installation from there.....your machine is trying to boot from the hard drive that has no OS on it.
Mar 29, 2011 | Dell Dimension 2400 PC Desktop
I need directions on how to reinstall the hard drive on a dell dimension 2400. I basically need a system restore. I have the reinstallation Cd, just need directions. THanks Also, i know how to download...
Hello
Regrading restoration you need a bootable CD inserted in CD drive and boot from that Cd by changing the boot sequence "boot from CD", during installation it will ask for format/partition of Hard drive, do if you want, after installation of windows you need driver, get drivers from link below:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_PNT_P4_CEL_2400
and install them as well,
feel free to contact for more information, good luck, do rate the solution if got help
Dec 04, 2010 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2400. My starts up fine
Most likely a motherboard issue.
Also ensure the CPU Heatsink is firmly attached. If the heatsink is loose, replace the plastic heatsink retainer
If it is secure, then the motherboard is the most likely failure point
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
May 19, 2010 | Dell Dimension 2400 PC Desktop
I have a dell dimension 2350. I want to take it back to factory setting how?
If you have the original dell restore disc's
then insert disc one and reboot the computer
As it boots up enter the BIOS and in there tell it to boot from CD first.
It should then boot from the restore CD and from then on just follow the prompts.
ALTERNATELY it may offer as it boots up a "press F? to start restore" or similar use that option to start the restore process.
Bob
ExMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Feb 21, 2010 | Dell Dimension 2400 PC Desktop
Tryed ctrl f11 bring to boot from cd only will boot from diag disk not off restore cd
For your dell system there is no restoration disks available, your system might have restoration partiton, so if the factory image is availabe for your system then you can use the ctrl f11 to restore it to factory condition - no disks are required all the info are saved in the image restore parttion in your hdd.
Jan 14, 2010 | Dell Dimension 3000 PC Desktop
Back to manufacturing settings as if brand new
When you purchased the DELL, you should have received a set of "System Restore" CD-ROMs. If so, insert the first disk, and restart your computer, telling it to boot from the CD-ROM, rather than booting from your disk-drive, and choose to reinstall Windows, with the additional Dell add-on software.
If you don't have those CDs, find the unique Dell ID (usually a white sticker on the back of the desktop, or the bottom of a laptop), and telephone Dell, and order a replacement set of those CDs, and then reinstall, as above.
Dec 05, 2009 | Dell Dimension 2400 PC Desktop
After installing Vista SP2. computer tries to reboot, but cant configure update 3of 3, so it reboots to start all over. tried setting CD as 1st boot, hangs waitng for CD-rom then boots off HDD. Tried...
ok go into your bios and load default settings.
set your cd-rm as your first boot device. then HDD.
save settings and exit. allow unit to reboot.
you can contact me direct e-mail. rain_catcher000_6@hotmail.com.
so i can give you one on one technical support.
Nov 14, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Dell dimension 2400 blue screen fault - page fault in non paged area. bug code 50. did system restore and changed memory board still faulty jim brand
Most likely the computer itself, the mother board in the Dells aren't very good. I would suggest the next time you buy a computer you should get a Mac. You'll have no problems at all, and you'll find that Microsoft Office for Mac runs far better too.
Sep 26, 2009 | Dell Dimension 2400 PC Desktop
Selected boot device is not available
I had the same issue with my dell dimension 2400. The issue I was having resulted in the connection to the drive was loose. Try taking off the side of the case, find the drives in question and reseating the plugins. My pc was quite a bit older though and i don't know if this will be your solution, but its worth a shot. You can even try installing a different cable and swapping to another power supply plug.
Aug 10, 2009 | Dell Dimension 8400 PC Desktop
Dell dimension blue screen stop error
When you start up computer press F12 to force computer to load from CD/DVD rom . Once it detects cd follow on screen instructions. If for some reason it doesn't work then try another cd , might need cleaning or try another CD/DVD rom if you have more the one in you system.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
213 people viewed this question
David Payne
David Payne
