Question about IBM 11P836402 for ThinkPad R40 Monitor
IBM R40 Screen Problems
I have an IBM R40. When I boot up I actually get (for a brief period )a quick display of whatever should be presented to the laptop display. Then it goes blank. In the background(real faint) I can see the application and I can use an external monitor just fine. If I hit the little black switch above the keyboard, I will get a flash of whatever Windows screen is open displayed on my laptop screen but then it goes blank again. I can continue to hit the little black switch and again, it will flash whatever screen is open to my laptop screen but eventually thinks I am in shutdown mode and I have to hit a key to get it to come back up. Any help would be appreciated. Are there specific drivers with XP I should check? Is there a setting in CMOS I should check?
    Scholar:
  • 177 Answers
I think you have an inverter board thats just about dead. It's located in the screens plastic housing at the bottom of the screen just above the keyboard. It's about 4 inches long and a half inch wide.There's just one little cable connecting it. But you have to take your screen apart to get to it. It's easy to replace and relatively inexpensive but it does require a little disassembly skill.
Also ,I will need the exact part number from the bottom of your laptop. There are several different R 40 models, and 2 different screen sizes.
Posted on Jul 24, 2009
My thinkpad r40 has not display on the screen. Upon starting it will go green in color with multiple vertical lines across the screen. I can see the flashing of the cursor and can sign in, but cannot see...
There are a few options as far as what could be going wrong but unfortunately whatever it is, it won't be good. The options are: video card (probably onoboard, if this is the issue the whole motherboard will need replacement), driver board for the LCD display (cheaper fix) or the LCD itself (probably not the issue). The only way to know for sure is to take it in to a place that fixes laptops and have them look at it. They can order the part you need and install it for you or at least check it out and give you a quote. If it's the motherboard it would be better just to buy another laptop instead since it might cost up to $300.
There's a very low chance it could be driver software related but this could only be the case if it does it ONLY after starting windows and during the welcome screen. If it does it during that black screen with white writing when it boots up, then it's hardware since at that point no drivers are loaded.
Hope it helps.
Jan 18, 2011 | IBM 11P836402 for ThinkPad R40 Monitor
The display on my ibm thinkpad r40 is black after initial dim ibm screen. External monitor works fine though. This happened immediately after I used my ibm with a projector this morning? Fn F7 does not...
The problem youve discribed does seem to point to your back light has failed on the laptops lcd display, i dont know exactly how this would accure just using a projector though, go into bios again and try loading factory settings.
This problem could also be the inverter if you cant make out even a slight image on the screen.
let me know what happens. thanks
Jan 19, 2010 | IBM ThinkPad R40 2681
My monitor display everythink like magnafied, what can i do to back to normal
Change the screen resolution. Go to Control Panel - Display - Settings and change the Screen Resolution to 1024X768
If you still have problems, get back to me.
Sep 27, 2009 | IBM ThinkPad R40 2681
I have an IBM R40- I bought it off of Craigslist and had very few problems until one day- I tried to start it but after the initial IBM main screen it goes to a black screen and briefly shows a couple of...
If you are unable to boot into safe mode by tapping F8 during the IBM splash screen then you will need a windows Install disc to boot off of and fix your boot command. If you don't have a disc then try to borrow a friends, you need to boot off that disc do that you can get to the recovery console and fix your boot menu.
Sep 25, 2009 | IBM ThinkPad R40 2722 Notebook
The monitor screen is cracked. When you press it you can see the jel or whatever spreading. I was told that I needed a monitor,
Hi there
You have been given the correct advice.
Once your monitor screen has cracked the LCD ( liquid crystal display) tends to run or move, if you take the screen out you can replace it via the code on the back of the screen.
Good luck and thanks for using FixYa!!
Apr 20, 2009 | IBM ThinkPad R40 2722 Notebook
The display screen has turned black
When you connected the external monitor thto the laptop did it display?
If so then you have to reset the monitor port. Hold down the function key and find the FKEY that shows a picture of a monitor. Press that until you get the laptop screen back.
Typical use is:
  • 1 press = external monitor
  • 2 presses = laptop and dual monitor
  • 3 presses = just the laptop screen
Dec 12, 2008 | IBM ThinkPad R40 2722 Notebook
DOES NOT BOOT
You will get a better response if you pay for the expertise we have to offer!
Mar 19, 2008 | IBM ThinkPad R40 2897 Notebook
IBM R40
sounds like there is a problem in the hard drive. Go to google and search for Hirens Boot CD it is about $10 but its well worth it. Boot from this CD and run the Check Disc Utility(chkdsk) and some of the virus tools, this might fix the problem, otherwise it sounds like a bad CPU or faulty RAM may be causing this broblem
Jan 08, 2008 | IBM ThinkPad R40 2722 Notebook
Error Message on boot
IBM requires using a "branded" network adapter, meaning one that has IBM's name on it, no matter if it's broadcom,etc. There is a couple of workarounds for this problem which would enable you to use whatever wireless adapter you wish. I would google IBM R40, and error 1802 and you'll find the application you need. Unfortunately, I'm not able to offer it to you here.
Good luck
Dec 02, 2007 | IBM ThinkPad R40 2897 Notebook
Intermitent problem IBM-R40
If I understand you correctly you turned off your laptop and since then have not been about to boot up normally, occasionally getting a blue screen. Typically the blue screen also has some type of error message, can you tell us what that is? You indicate that booting from the CD drive is not possible, is that because you don?t have a working drive? In any case this sounds like a problem with system files or possible a device driver and a CD drive is almost certainly going to be necessary. Let us know the answers to this questions and any other pertinent history relating to this issue and we?ll see if we can help.
Mar 04, 2007 | IBM ThinkPad R40 2722 Notebook
Computers & Internet Logo
235 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
