Question about Acer Aspire One Netbook 8.9" Notebook
Humming noise on netbook
I have a netbook Acer and it has started to make a loud humming noise - can you please give me advice on how to fix it?THANks
  • gumbyreloade May 11, 2010
    Where does the sound originate?  Meaning what part of the device is making the noise... left side near network jack?  front right near switch to turn off wireless?
    Also, when does the device make the sound?  All the time?  If you turn the device off and restart into the system setup, does it still make the noise?
LG Tromm electric dryer model DLE5977B is making an extremely loud humming noise.
Humming is caused when the slow start capacitor on the motor fails. Better to buy a new dryer as the motor is usually around $160. Yours is $145. I suggest you take professional advice on such a high outlay rather than risking the advice of someone who hasn't physically checked the machine. I have two pro dryers in my hotel fail, and they buzzed.
LG Dryer Model DLE5977B Parts
Feb 02, 2017 | LG Dryers
Maytag Range MER5875QAS Problem
You may have a serious electrical problem. Or you may need a new element.
Please provide more info as to the source/location of the smoke.
Brian
Jan 19, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
My Acer Aspire One AOA150 's fan is very loud and warm
I'd suggest that you carefully pull the base of your Acer apart - taking out the screw, and keeping track of them. See if your fan is dirty - I have an Acer as well, and if it's dirty, it get loud, and HOT!
A quick cleaning does wonders!
Feb 15, 2010 | Acer Aspire One AOA150-1784 Netbook
MOTOR IS WORKING AS IT STILL HAS A HUMMING NOISE BUT THE BLADES ARE NOT CHURNING, PLEASE CAN ANYONE GIVE ME SOME ADVICE? THANKS
If the motor is growling or humming loudly and the blades are not turning the motor IS the issue. For some reason, either electrical or mechanical, it won't turn. You will probably need to take it to an electric motor repair shop in your area for inspection and a quote on repairs vs. replacement.
Jan 04, 2010 | Saniflo & Saniplus& Macerator Pump
Hi There!
The fan may be a little loose that cools the processor. Give us a call and we can check it over for you and replace it for a new fan.
Regards
James
Manager, Gigafix Ltd
http://www.gigafix.co.uk
Apr 14, 2009 | Acer Aspire One PC Notebook
Humming Sound
dear friend
it may be cpu fan
if it is not in warranty
just take it to technician
he will open it and cleanup the fan and put some grease on it
if it is in warranty , its better to take it to service centre
thanks
Apr 10, 2009 | Acer Aspire One AOA150-1784 Netbook
Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
Apr 03, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Acer Aspire One Netbook 8.9" Notebook Logo
508 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
