Question about Asko W6021 Front Load Washer
Washer will not drain
I have rewashed and drained the washer but it still will not empty so i can open the door
  • 47 Answers
IT COULD BE THE BELT OR MOTOR COUPLING ON YOUR WASHER.
Posted on May 14, 2009
Wont drain..door locked..what do l do?
put drain hose below water level when empty should spin
Apr 17, 2015 | Washing Machines
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
MAH8700AWW washer door wont open
hi adriana it is possible there is still water in the drum if that is the case the door wont open untill you empty it,this can be done by draining the water through the filter drain located at the front of the machine ,i hope this helps .
Dec 29, 2011 | Whirlpool LHW0050PQ Front Load Washer
Spin cycle does not work and clothes in washer with door locked. have tried to rewash clothes but still stuck on rinse/spin cycle and door will not open to get clothes out of washer, even on the off...
It could be that it hasn't been able to drain all of the water in time.
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 08, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Why does my machine blink f 21 when it starts to fill then it stops and does nothing
The F21 error code indicates a long drain time on this type of washer. The door will not unlock if the washer control detects that water is still in the tub. To manually unlock the washer door, take these steps:
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel as shown in the first image below.
  3. Carefully reach up through the bottom opening and pull the release tab on the bottom of the door lock assembly until it clicks. NOTE: Internal metal edges in the washer can be sharp. Protective gloves are recommended for this procedure.
By pulling the manual release tab on the door lock assembly, you should be able to get the washer door open.
After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the large item filter out of the drain pump assembly as shown in the second image below. You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Feb 06, 2011 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My maytag washer mah-24 have a "nd" msg. which mean "not draining" and now i cannot open the door to take the clothes out. pls. help.
Unlocking the door:
Turn on the washer, but don't start any wash cycles. After a few minutes, the door should unlock itself.
Troubleshooting the "nd" message:
"nd" means "no drain". Empty the (now unlocked) washer and fill the wash tub with just enough water to see a bit of water at the bottom of the tub. Run a drain cycle and check a) if it drains and b) if there are any unusual noises while it is draining. If either event occurs during the drain cycle, the drain pump may have to be repaired/replaced.
Nov 25, 2010 | Maytag MAH2400A Front Load Washer
When i hold the start button, the machine will not begin the cycle
get a chair look behind the washer and unplug the electric cord and then wait a few seconds and plug it back up then do a drain and spin to get the washer to finish gettting the water out so you can get the door open or just rewash the clothes. You may have to try this a few times. My wife has had the same problem and this is what I do to get the washer going again.
Nov 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a top load GE model #WBB4500G, and our clothes comes out smelly. It is horrible. We are constantly having to rewash clothes, this is rediculous. I've heard of this problem with front loaders, but we...
You have an inner and an outer tub. The outer tub may be holding too much water. The smell may be the soured water in the outer tub. You should take the washer outside and drain it completely. Then replace the drain hose before you put it back inside. Hopefully, this will slove your problem.
Sep 04, 2009 | GE WSXH208A Front Load Washer
Stinky, moldy smell on clothes
I agree with your concerns, but, unfortunatly, leaving the door open and emptying the drain trap is all you can do. I would also start washing your laundry with at least a 1/2 cup of borox with each load. This will help with the smelly cloths as well as running the monthly clean cycle or an empty express wash with only bleach.
Jun 06, 2009 | Kenmore Elite 45986 Front Load Washer
Aquarius Hotpoint.. keeps doing rewash after rewash.. door won't open when i switched the washer off its like its trying to either empty water, but making a noise when its trying it.. what wrong and can it...
Unplug First!!!!
You Can Pry The Top Off With A Big Flat Head Screw Driver Where The Seam Meets The Casing.
Then You Can Check The Belt Thats What Is Most Likely Your Problem. Take The Broken Belt To Your Local Auto Part Store And Tell Them you Want One That Size And Replace.
Jan 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Asko W6021 Front Load Washer Logo
144 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
