Question about Gateway Computers & Internet
Will not turn on
Daughters computer will not turn on. Charger was checked and its ok. The battery will not charge even though its on charger. Any help appreciated.
  • Gateway Master
  • 32,281 Answers
Check the adapter with a multi-meter, the voltage on the connector plug should be slightly higher than the voltage that is printed on the label attached to the adapter.
OR
Borrow a working adapter, make sure it is the same or compatible to test your laptop.
Posted on Apr 15, 2009
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
Why won't my er700-2 turn on even though its charged Help
Try this disconnect the ac charger from laptop then disconnect the battery with boh battery and charger disconected press and hold power button for 1 minute put back ur battery then plug back charger turn on ur laptop good luck
Aug 31, 2014 | Computers & Internet
Why won't my daughters acer chromebook charge?
You need to verify if the Charger is Working if it is
you need to verify if the battery is well inserted in the laptop
if this OK then try connect the charger to the laptop
open the laptop and while it is on remove and reinsert the battery
Jun 30, 2014 | Computers & Internet
What do u do when your phone won't charge even
charge your battery on another phone and then place your battery in your phone and switch on your phone and connect the charger to it if still it isn't charging then check your charger and if the charger is ok then you need to repair your phone manually or by taking it to authorized dealer
Apr 25, 2012 | Cell Phones
My daughters Acer wont charge so the battery is dead. The laptop wont even come on when the charger is plugged in but i have an Acer an charged her battery in mine then it charged and it worked in hers. Is...
first try to use your charger into another laptop, if the the another laptop was charged using your charger, it means your battery is the problem, but if it is still not charging it means the problem is your charger. then try your battery to use it into another laptop, as same as the i mention in the charger, if they or both fine, maybe the problem is the batery terminal of your laptop.
Dec 07, 2010 | Acer Aspire 5315 Notebook
I cant seem to turn on the phone, and its just a blank screen. i checked with the battery with another same phone and its battery is still full and it can be on. however, when i use the phone, i just cant...
ok so you are saying your battery is ok.Then it could be your charger or phone that is the problem.You are best going to a suppliers shop where you can try another charger.If battery and charger are ok then it must be the phone, and ask for a replacement.
Hope it helps!
Dec 22, 2009 | Computers & Internet
Mp3 player shows that battery is dead even though its charged and the screen only works if i hold the on off switch the whole time
try inserting the charger to a different socket until it works. if not you might be having problem with the charger. not the mp3 player and if you already triedto change the charger you might be having problem with the battery of your mp3 player ok send me a message for more concerns.
May 04, 2009 | SanDisk Sansa m240 MP3 Player
TX IS DEAD
The T3 will appear dead until the battery has SOME charge. A totally dead battery, even though plugged into a charger, will not let the T3 turn on. You mention a previous charger problem. Could be a bad charger, or a bad battery. Check to see if the charging light is on on the T3 when you think you are charging. If it is not on, try another charger. If it is on, you may have a bad battery.
Jim
Sep 09, 2008 | Palm Tungsten T3 Handheld
Motorola w375 wont turn on?!?
Most likely, what has happened is that the camera charger, even though it fits, puts out different voltage and amperage than the motorola charger. You've either (hopefully) just damaged the battery, or the phone itself has become damaged. I think Verizon, or Suncom also has phones with that same battery. I would recommend trying one before buying it. If it works, great... if not, you'll need to either have the phone professionally repaired, or replaced because it most likely fried the power relay circuitry in the phone. Unlikely that your problem is software though.
Aug 04, 2008 | Motorola Mobility W375 Cellular Phone
Computers & Internet Logo
54 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
