Question about Milwaukee Drills
10-32x1 Left Hand Chuck Screw for Milwaukee Magnum Holeshooter
Cat# 0232 23b, I lost my chuck screw during a wind storm last week. Tornadoe blew by just down the road and the work bench in the barn had a few things rearranged as a result. I can buy the screw from a few places milwaukee suggest, but they have about 2 weeks special order, plus cost and $10 shipping for a little screw.
Checked all my local hardware stores, even checked a local Milwaukee dealer and they were gonna charge the same.
Can anyone suggest another route or someone that can put the screw in an envelope for letter postage? Otherwise I am looking at just buying a new drill bc I can't see myself spending $11 for a .50 screw.
    Top Expert:
  • Milwaukee Master
  • 49,190 Answers
Any reversible drill will have the lh screw in the chuck
cruise the garage sales, dump shops etc and get a dead drill and remove the screw
could be phillips head or hex head but that will not matter
if you have access to a quality bolt retailer ( not a hardware shop) they will have the screw
go to an appliance repair shop that repairs drills as they may have a dead drill with the chuck still attached
Posted on Apr 04, 2017
3 Suggested Answers
  • 142 Answers
SOURCE: Milwaukee magnum hole shooter drill cat #0234.1 chuck removal
counterclockwise
Posted on Jul 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: Variable speed doesn't work on Milwaukee Magnum hammer drill
how new is the tool. Give me the serial number and I will come up with a solution, also what is the switch number you bought. Let me know.
Posted on Jan 02, 2010
Chuck only closes half way
could be a couple things, the chuck retainingn screw in the center might have loosened up jamming the jaws when trying to close. Open the jaws all the way and tighten the screw, it is left hand thread. Or the chuck itself is damaged and depending on how little use might be covered under their warranty. I would check the screw first.
Feb 05, 2012 | Electric Milwaukee 2610-24 M18 Driver...
I want to know the steps needed to replace a 1/2" keyed chuck.on a Milwaukee 0234-6 Magnum Drill
they make a service fixture for that BUT if you can find a thin wall open end wrench that will fit behind the chuck on the hex of the spindle you can still do it. What you will need to do is remove the left hand chuck retaining screw, put the wrench or similar item over the hex and then put the chuck key in a hole that is about a 30 degree so that you can strike it counter clockwise to remove. That chuck is on tight and there no easy way to remove it like you can do on cordless items.
Jul 31, 2011 | Milwaukee 0234-6 1/2" Magnum Drill 0-850...
My keyless chuck will not tightten all the way closed....seems to catch on something
Open the chuck and see if the screw inside the chuck has backed out. The screw is left hand thread so you will need to turn it to the left to tighten it. It may be an allen or Torx head screw.
Jul 15, 2011 | Milwaukee 2690-24 18-Volt Hammer-Drill,...
How do I change the chuck on my milwaukee right angle 1/2" drill? It has snapped off behind the chuck
Take digital photos when taking the front metal gear box off the drill. Next carefully remove the two plastic halves of the drill if needed to gain access to the shaft that holds the chuck.
Replace the broken threaded metal part that the chuck screws onto.
Normally chuck replacement involves unscrewing the small screw deep inside the chuck on a metal shaft has a left hand thread. Next use a large allen wrench tightened in the chuck with a mallet to loosen the bad chuck. Reverse to install new chuck.
Feb 01, 2011 | Drills
Chuck is stuck open cant get to free how do i replace chuck
You need to secure the drill - perhaps in a vise - and insert the chuck key (if it is a key-less chuck you may have to use a pipe wrench or something similiar) and give the key (or wrench) a sharp hit to release it. The chucks are screwed onto the drill with a right hand thread. Let me know if this works for you. Thanks
Jan 02, 2011 | Milwaukee 0200 20 Drill 3/8 1200 Magnum
I need the reverse threaded insert that the bolt that holds the chuck on the right angle head on a magnum holeshooter
Go to this LINK and find the part/diagram that can help you.
Please thumbs or post back,thanks
Nov 02, 2010 | Milwaukee Garden
Chuck is very hard to adjust
Try lubrication, and check that the retaining screw, down inside, has not come loose. failing all of that, replace the chuck.
Oct 02, 2010 | Milwaukee 0234-6 1/2" Magnum Drill 0-850...
Need to remove the chuck on my 3/8 milwaukee drill. I opened the chuck and removed the screw in the bottom but can't get it off. does it pry off or unscrew? right or left hand screw???
if this is a cordless drill please review the tip section, if not the spindle has a hex that you can put a thin wrench on and the threads are standard meaning you would use a chuck key or allen wrench to hit it in the counter clockwise position to remove it. Let me know if you have any problems
Nov 23, 2009 | Milwaukee Tool Drills
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
885 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
