Question about 2wire HomePortal 1800HG Router (1000400229000)
My internet keeps going offline and on every 15seconds
    Sergeant:
  • 175 Answers
Hi Dear. So many reasons. Using PSTN, ISDN or DSL?
Posted on Apr 14, 2009
  • Hassan Raza
    Hassan Raza Apr 15, 2009
    Do the following step by step;
    1: Ping local IP address of your DSL modem with -t command, eg, ping 192.168.1.1 -t or ping 192.168.0.1 -t Check status.
    Next parallel step;
    2: Ping NS (Name Server) IP address of your DSL service provider with -t command. To get NS IP address, write nslookup in RUN or command prompt. Check Status.
    Next parallel step;
    3: Ping yahoo.com -t Check status.
    1: If local IP of DSL modem is pinging perfect and without Request time out, it means your modem is OK, if there is sequential data lose after some replies, it means your modem is not functioning properly because of excessive room temperature, or, modem is malfunctioning due to misconfiguration, or, modem is malfunctioning due to software or hardware issue, change patch cable of DSL modem to CPU. IF you knew your default configuration of DSL modem, you can RESET your modem and do these 3 steps again or contact your Service Provider.
    2: If local IP ping is perfect and NS ping is with sequential data lose, might be because of DSLAM Port hanging issue, Contact your Service Provider.
    3: If local IP and NS IPs are replying perfect and pinging yahoo.com is with sequential data lose, Contact your Service Provider.
How do you uncheck work offline when it keeps checking itself acer aspire one
To resolve this issue, follow these steps:1. Start Internet Explorer.
2. On the File menu, determine whether the Work Offline option is enabled.
Note If this option is enabled, a check mark appears next to Work Offline.
If this option is enabled, go to step 3.
3. On the Tools menu, click Internet Options.
4. In the Internet Options dialog box, click the Connections tab.
5. Make sure that the Never dial a connection option is selected.
6. Click the Advanced tab.
7. Under Browsing, click to clear the Enable offline items to be synchronized on a schedule check box, and then click OK
Apr 26, 2012 | Acer Aspire 5500 5570-2609 Laptop
I got the newest version of Yahoo mail and the Yahoo messenger keeps on going offline when i try to send an IM to someone. help please.
the problem would be on your internet connection. please make sure that you have a stable internet connection.
Jun 16, 2011 | Yahoo Messenger
If im going to open my internet explorer, it will display "working offline
it could be that your IE is set to "Work Offline" or it tried to connect but didn't find a connection setting.
1. Try to configure your internet setting
a. Go to control Panel -> Internet Options - > Connection Tab then LAN settings, then click on "Detect connection automatically
if it still dont work, do this:
2. Open your Internet Explorer, Click on FILE the click on "Work Offline" at the near bottom and hit RELOAD/REFRESH (or press F5)
Regards!
Jul 11, 2009 | Computers & Internet
3 boxes keep popping up saying connecting to internet... dialing connection.... working offline. how can I make these go away. they drive me crazy. they are worse when I am browsing ebay or like networks....
Open Internet Explorer
click tools-->Internet Options
Click the Connection tab
Check the box that says "Never dial a connection"
Click OK and you're good to go
Jul 10, 2009 | Computers & Internet
I keep getting a pop-up showing I Aam working offline - I don't know how to get online. Thank you. CM McCarty
no problem go to tools up the top of your browser and click tools scroll down and click work offline to change option back to work online if that makes sense to you.
welcome
Jun 22, 2009 | Computers & Internet
I cannot get offline when I install Internet explorer 8, it always says not responding. So I have to go to my windows task manager and keep clicking on the not responding so I can get offline. Or turn off...
If you are using the beta version, this is a normal scenario. If you are using IE 8 latest check whether you have downloaded the proper version which suites your windows platform. Go to add remove programs-> windows components and select internet explorer to remove it. Then re-install the new one. Make sure you patch it usually.
Jun 13, 2009 | Microsoft Internet Explorer 8
My HP Deskjet D2360 keeps going offline. What
First try reinstalling drivers for your printer from original CD, if that doesn't help update your drivers from the Internet.
If none of it helps, try connecting your printer to another computer and see if it will behave the same. If it does, then printer is ready for retirement.
May 04, 2009 | HP DeskJet F380 All-In-One Printer
Internet Issues on Lenov0 8922
if it tells u offline then follow the steps:
>> open the internet explorer...
TO LOOK FOR VERSIONS OF Internet Explorer(IE) ...open IE and go to Help on top and click on "About IE"
>>for IE 6.0 ...go to File>>and look for "Work Offline" (make sure its unchecked)...if thr is a check mark then click on it
>>for IE 7.0...go to Tools on the top-right corner and look for "Work Offline" (make sure its unchecked)...if thr is a check mark then click on it
Dec 03, 2008 | Lenovo 3000 C200 8922 - Core Duo T2060 1.6...
Can't connect to internet
make sure that your connected. on IE go to tools, internet options. connections and setup on the top. keep going. let me know if u need help.
good luck
cheers
Aug 13, 2008 | Compaq Evo N610C Notebook
Offline
hello
i am assuming that you have an ip address /dns /internet settings provided by your internet service provider.
(1)
open internet explorer
click on tools
internet option
select connection tab
remove items from Dial-up and virtual private network settings
or select the option which says never dial a connection.
(2)
under connections tab
select Lan setting
check the box automatically detect settings
restart your PC
(3)
sometimes computer virus do make an internet connection...
hope this post helps
Aug 07, 2008 | E-Machines T2682 (000002965) PC Desktop
Computers & Internet Logo
761 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
