Question about Dell Inspiron 6000 Notebook
Ram change problem
Hi I have Dell inspiron 6000 with 1GB ram(512 + 512).I bought a compatable 1GB (Kingston) one ram and tried to replace one 512 MB ram. But my laptop stop working.It automatically switch off after few seconds.I tried to put old RAM back but my laptop is still not working. Please suggest some fix for this problem. Sanjay
  • sanjaykalsi Sep 15, 2007
    still it is not working
    Sanjay
    Problem Solver:
  • 17 Answers
There should be a reset button on bottom of laptop....if not...remove battery, power supply plug and remove the mbottom panels....under one of them is a battery the size of one of two....either 6mm in diametre or one of 22mm in diametre...remove it and leave laptop for about 5 min....remove memory,touch the memory's golden edges briefly with your fingers to discharge charge in memeory.put everything together...should solve your problem. JJ
Posted on Sep 14, 2007
SOURCE:
How can I upgrade/improve the capabilities of my Inspiron 1200
The best and quickest improvement is to add more RAM. Add another 512 Mb of RAM. If you already have a 512 Mb of RAM module then add another 512 Mb RAM module. If your laptop has 2X256 Mb RAM modules then you need to remove these and insert 2X512 Mb RAM modules.
The reason why you have 504 Mb RAM is that the video card has grabbed 8Mb of RAM off the main memory.
May 21, 2010 | Dell Inspiron 1200 Notebook
I have installed 1 GB + 512 MB DDR II RAM, but it read only 1G I have just bought the Corsair 1GB RAM (DDR II 667 MHz, 6400), and installed it in the slot 1 of my motherboard, but it only read as 512 MB. (...
Nowadays, motherboards supports only a selected number of RAMs. You have to read the manual and select from the given models. I am not talking about DDR2 or 667MHz. The manual will state the manufacturer (ex. Kingston) model no (KVR667XXXXXX) etc. Only those stated in the manual will work correctly with your motherboard.
Aug 14, 2009 | Biostar P4M800 Pro-M7 (P4M8PROM7)...
Won't Reboot after installing new RAM
If you remove the 1GB memory that you were trying to install and it will boot, then it is your new memory that is not compatible. Check here for what memory will be compatible with your laptop.
Jan 02, 2009 | Dell Inspiron 6400 Notebook
2 GB or more RAM is not functional
try maybe theres a problem in memory compatibility...dude first try to put same memory card brand and specs
Sep 01, 2008 | MSI K8N Neo4-F Motherboard
Dell 5100 laptop memory upgrade
try removing it again power on then off. again put yr ram it should boot. less u want to may be remove the processor then put it back as well at times they could stop system from booting
May 23, 2008 | Dell Inspiron 5100 Notebook
Dell Inspiron 2650
Here are the specs of your RAM:
  • Module Size: 256MB
  • Package: 200-pin SODIMM
  • Feature: DDR PC2700
  • Specs: DDR PC2700 • CL=2.5 • Unbuffered • Non-parity • DDR333 • 2.5V • 32Meg x 64
  • MAX 512 MB
    Here is where I normally Buy RAM:
    http://www.crucial.com/store/listparts.aspx?model=Inspiron%202650%20Series
    May 20, 2008 | Dell Inspiron 2650 Notebook
    Getting access to bios in Dell Inspiron 1300
    No, The amount of RAM the integrated video uses is dynamically adjusted depending on the loading of the video and the total amount of RAM installed.
    If less than 512 MB RAM, the video is limited to 64MB, 512 to 2 GB max video RAM is 128 MB.
    If you want to upgrade RAM to improve performance, check the link below:
    http://www.crucial.com/store/listparts.aspx?model=Inspiron%201300
    2 GB for $50 + tax, not bad
    May 17, 2008 | Dell Inspiron 1300 Notebook
    Dell Inspiron 6000 Notebook Logo
    131 people viewed this question
    Ekse
    Clive
    Clive
