Question about Plumbing
Water filter system leaks at tap
Whirlpool reverse osmosis filter system WHER12 System started leaking around the base of the faucet assembly that fastens to the sink. The leak stopped when I cut the water supply off. It starts again regardless of whether the tap is on or off. Any suggestions?
  • Petraud May 10, 2009
    whirlpool reverse osmosis tap from Lowe's
The line from the faucet to the drain was plugged. I cleared the line and the system is working well.
Posted on Apr 15, 2009
  • gene2u Mar 16, 2011
    Thanks for the update. I read the same advice on a different site. I also tried tightening the connection where the faucet attaches to the sink. I think it's working well now, though I'm not sure yet, and which adjustment fixed it.
Jameco single handle kitchen faucet with spray is hard to turn
make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals
If a sillcock wears out, replace the washers
If a compression faucet drips from the spout, replace the washer and/or the seat
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type
If a ball or cartridge faucet leaks from the collar, replace worn O-rings
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
Kinetico reverse osmosis water flowing very slow
I am guessing you have checked to make sure the water flow into the osmosis system to make sure it is at proper pressure? If so is this a whole house system or just for the kitchen? If it is a whole house do you have the same problems in other parts of the house?
Jan 21, 2013 | Refrigerators
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
Leaks on the top of black box of culligan water softner under sink system
Is this a reverse osmosis drinking water system? If it is it is an H8 RO. If so shut the water off that feeds the RO. The leak is probably coming from one of the fittings, they can be cut by the compression fittings and leak.
RJ
Feb 13, 2011 | Culligan Under Sink Water Filter
I want to unhook my reverse osmosis how do u do that and what are the steps
Here are the steps to remove your RO system. Put a pan and a couple rags under sink to catch any water that might spill.
1. Label all the lines from RO (with masking tape) to remember where they go.
2. Turn the water off to RO system
3. Run all the water from the RO tank
4. Turn the valve off on RO tank.
5. Remove the line to the RO tank and pull tank out.
6. Remove the line to the RO drain.
a. If there is an AIR GAP faucet this line may go there first
b. plug the whole for RO drain or replace the standpipe
7. Remove the product line from RO faucet
8. Remove the water line feeding the RO system.
9. Make sure the valve feeding RO is shut off completely
a. If this valve is a piercing valve you may want to consider replacing the section of copper
plumbing because it will eventually leak if left unused.
10. When re-installing the RO remove old filters, sanitize system and replace with new filters.
RJ
Nov 11, 2010 | Culligan Under Sink Water Filter
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
Ice maker mal-formed ice
no "slug" is available however you could just use a reverse osmosis diaphram pressure tank to boost the water pressure. you can also use a water supply tube to bypass the in-refrigerator completely.
Jul 22, 2010 | KitchenAid Superba Architect KSCS25IN Side...
I own the Wher25 Reverse Osmosis system. I
There is a blue cap on the body of the white pressurized water tank. Twisting off the blue cap, you will see a air nozzle - similar as those on the tire. You need to pressurized the tank to 60 PSI. I spend hours to figure out this solution on my own system.
Mar 14, 2010 | Home
Plumbing Logo
459 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
