Question about Sony KP-43T70 43" Rear Projection Television
Sony KP_43T70 Ive had this tv for about 7 yrs now and last night I noticed the colors started to change.The picture itself seems ok but you can see the three colors in horizontal bars rolling down the screen from top to bottom continuously like an old b&w tv used to do. So face change from red to blue to green.Whats up with it? and is it an expensive repair?
  • lasertekk Nov 28, 2007
    Every 40 minutes, the screen flashes red, then green then blue. It then equalizes and goes back to normal. It almost looks like the tv is kicking into a self diagnostic mode. But again, 40 minutes later, it does the same thing. Email me personally at [email protected] if you have a solution or want to discuss this.
  • Sony Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid Sony KP_43T70 - 65af323.jpg>
65af323Sony KP_43T70 - 2c07611.png=
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 28, 2009
  • 42 Answers
SYMPTOMS
Double picture on all channels.
RESOLUTION
Found IC1502 on the G Board defective.
Service manual can be requested at http://fletchersite.com/contact.php
Posted on Jun 01, 2008
SOURCE:
Lamp part number
KP-43T70 is a CRT based rear projector and does not use a Lamp like newer LCD/DLP projectors. It uses 3 (Red, Green, Blue) glycol liquid cooled CRT's (like the picture tubes of yesteryear) to produce the image/light as opposed to a Lamp.
Nov 27, 2013 | Sony KP-43T70 43" Rear Projection...
Sony kp-43770 tv red and green colors will not align how do i correct this,i have used the focus button no success
convergence chips will need to be replaced and I think model number is not correct that was posted, kp-43t70 instead of kp-43770?
May 20, 2012 | Televison & Video
Green missing sony kp43t70 green lamp is on tv working, convergence ok
Press the menu button, if the menu has green missing as well it's the tv. If you can't tell with the menu, use a second source, being a dvd or a gaming system. If the green is still missing make sure you use different cables, it will be the tv. if only one source is the issue it will be the source that is missing the green color.
May 05, 2010 | Sony KP-43T70 43" Rear Projection...
I have a Sony KP-53VP0 Rear Projection TV Kinda Cloudy Picture.
take off the back of the tv and clean the lenses and the foggy picture will go away
Jan 14, 2010 | Sony KP-53V90 53" Rear Projection...
Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
Apr 17, 2009 | Sony KP-46WT520 46" Rear Projection...
Colors no aligned
Hi Chin,
Please check faded color resistors (in big size) on D board and also check dry solder joints on D board.
If above seems OK then ICs STK-392-560 are suspected and needs to be replaced.
Let me know if you need further info.
Nov 29, 2008 | Sony KP-51WS500 51" Rear Projection...
Screen/Picture Flickering
alo all..
i got problem wif my TV... sony wega trinitron 29inch..
- last 2 night... the TV @ screen slowly lost color for 2-4second... and after that it suddenly turn off for 5-10second and turn back on itself. the led blink 3-5times....
what the problem to my TV?
Jan 09, 2008 | Sony KP-46S25 TV
Kp-43t70 red out of adjustment
It seems, from your description, that the convergence circuit is failing. The usual components that fail are the convergence integrated circuits.
Dec 20, 2007 | Sony KP-43T70 43" Rear Projection...
Sound stays on & picture goes to blank screen
I do not see any reference on this problem and I even checked with Sony. If you are on a cable box, I suspect that is the problem.
Oct 25, 2007 | Sony KP-43T70 43" Rear Projection...
Sony KP-43T70 green ghost problem
The cause of the problem can be that the CRT-s are getting weak. Life span of CRT is around 30000 hours of working time. Please calculate. If you need more info please advice.
Apr 03, 2007 | Sony KP-43T70 43" Rear Projection...
Sony KP-43T70 43" Rear Projection Television Logo
493 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
