Question about Acer Aspire 4720 Notebook
The laptop comes on. The Microsoft logon sign come up and then the laptop goes dark. The laptop stays powered on, but the keys, etc. don't wotk. Acer Aspire 4720Z camera laptop.
  • 1 more comment
  • h vr
    h vr May 11, 2010
    Hello!
    You can try tapping the F8 key while starting up the laptop.
    This should bring up a couple of options. select the option listed as "LAST KNOWN GOOD CONFIGURATION".
    This will recover the laptop to the last time it booted succesfully into windows.
    Good Luck!
  • ultimitloozr May 11, 2010
    Try to boot into Safe Mode by pressing the F8 key when the computer is booting as you see the first Windows screen appear and selecting Safe Mode from the menu, Does it work properly in Safe Mode?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Can you get into safe mode?
The set was hit by lighting I replaced the power board no the set comes on for just a second dark but don,t shut down;
Your laptop is toast and rather than sink more money into it , might just be better to cut your losses and replace it with another laptop running Windows 7 - stay away from 8 and 10!
Aug 26, 2015 | Computers & Internet
Can't logon to my acer laptop it says the following, the user profile service failed the logon user profile cannot be loaded
Shut down your computer. To do a hard shutdown hold the power button down until it turns off. You probably need it to go to last known good configuration. To to this 1. find the F8 key (keep finger on it(not pushed yet). 2. Turn Power button on and immediately start tapping F8 key. This will take you to a screen with many options; Last Known Good Configuration is one of them. It should start up. Hope this helps.
Apr 27, 2013 | Acer Computers & Internet
The lights come on but nobodys home, i get a dark gray screen, it trys to to start then stops the lights stay on
Try plugging your laptop into a desktop monitor to determine if it's a display problem or goes deeper than that.
Dec 24, 2009 | Acer Aspire 4720 Notebook
I cannot logon to my PC
Start your PC in safe mode, to do this repeatedly tap the F8 key as soon as you turn the power on. This will then bring up an "options" screen listing boot in safe mode, safe mode with network support etc. Just use safe mode. If it goes directly to windows instead - shut it off and try again til u get the safe mode screen. The arrow keys control the selection to choose.When it starts in safe mode a black screen will usually appear with a bunch of writing, this is normal, after that it may "hang" for as long as 5 minutes, before coming up with a login screen. Sometimes hitting enter or escape will bring up the login screen faster. When you have a login screen, login and disable the updates using the software control options for the software that is trying to update. You might also go to control panel, administrator options, then services and disable automatic updates temporarily. When your pc starts in safe mode - it starts with minimal drivers and does not run updates- this allows you to change settings. You can then reboot normally and it should start properly without updating before starting.
Aug 29, 2009 | Acer Aspire AM1610-U1201A PC Desktop
My laptop wont turn on fully
you could have a boot virus. to restore, switch on laptop and repeatedly press F8 key until you get a boot option screen. you can select the bottom option, to go back to the last settings that worked. if this doesn't fix the problem, then you can restore your laptop using either the F10 or F11 key when you switch on your laptop. one of these keys takes you into system restore. you may have to press the Alt key + F10 or F11.
Jul 17, 2009 | Acer Computers & Internet
Laptop screen goes dark.
Is your computer setup to go to sleep when you close the lid?
Click on start -->control panel-->power options and then check the option that says choose what closing the lid does. You have to change this setting to 'do nothing' if you want the computer to stay on when you close the lid.
May 19, 2009 | HP Compaq Presario C700T
Acer estensa 5620
Might be something wrong with your display settings. Between the Acer logo and Microsoft logo, try pressing F8 about twice per second. A menu appears. Use the arrow keys and choose the one with "VGA-mode" using the enter-key. Wait while the computer boots. Set a compatible display resolution for your display.
Nov 03, 2008 | Acer Aspire 5610 Notebook
An acer9410-4317
because your powersaving settings is in the power saving mode
Jul 16, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 4720 Notebook Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
