Question about Agri-Fab Agri Fab Spreader
The front not straight when driving
While mowing, I hit a fence post, and the front left wheel went out to the left (sideways) now when the steering wheel is turned straight for the right wheel, the left wheel still turns to the left. Is the axel bent?
  • 68 Answers
Its probably bent or broken one of the tie ends on the steering. Ring your nearest suppier they will pick it up and repair it.
Posted on Aug 30, 2009
I was going 80 miles an hour on the interstate and it felt like my tire was going to fall off the car shook really bad and my steering wheel turned sideways and I was still going straight and it did it...
indicates that a tie rod end has broken or other very serious problem has occured
take it to a front end suspension and steering specialist shop for a proper diagnosis and quote
Mar 08, 2018 | Cars & Trucks
When steering is centered the left wheel is out to the left and the right is straight
Unless you have had an accident or Kerbed the wheel it is probably your tracking is out/ track rod end loose!
Sep 10, 2015 | Cars & Trucks
My 1957 ford 601 is very hard to steer to the left but fine to the right. Whats wrong
I believe someone driving the tractor has hit a hole or an object hard enough to stop the tractor and literally spun the steering wheel all the way to one side, thereby bending the spindle or the link connecting the steering box to the spindle. Drive the tractor straight on level ground, stop and get off then look standing at a 25 yard distance in front of the machine looking at the symmetry of the front wheels. That will reveal spindle problems.
Dec 18, 2014 | Ford Garden
The lawn tractor hit a post and now the left front wheel is out of alignment. How can I make it aligned?
the steering tie bar (goes from left to right steering brackets and makes the wheels steer together) should be straight. if it's bent, that is your problem.
Nov 07, 2014 | Craftsman YT 4000 42" Briggs Stratton 24...
2000 jimmy steering problems
Check air presure and wheels if they streight
Jul 12, 2014 | 2000 GMC Jimmy
One of my tires is straight and the other one is pointed outwards. the steering wheel is sideways as like im turning
The easiest way to do this is straighten the steering wheel first Brandon. Next is to walk to the back of the truck and eye ball the left front tire from a looking from the side of the back tire. If that one is straight ahead before or after you adjust it, Now check the passenger side the same way.When both look straight, now take a tape measure and measure the distance from the center tread on the right front tire to the center of the left front tire.Say its 61", now do the same behind the front tires. It might say 58". You want to end up with the front measurement being 1/4 of an inch smaller then the back.
Feb 01, 2014 | 1999 Ford F150 Regular Cab
Multiple steering wheel problems
my daughter had this issue in a renault clio............ steering wheel tilted sideways while driving straight. she got new bushings.
driving your car in the state its in is quiet dangerous as you already know.
hope someone else helps you out. :-(
Apr 14, 2013 | 2006 Toyota Camry
My son was mowing, with our cub cadet 2166, and ran the left front tire into a fence and now the steering wheel wont work. You can turn it and it feels really loose but it isn't connecting to the
Check the two main gears. One at the end of the steering shaft and the other that it contacts. Some brands are adjustable where the large gear is held on by a bolt and an excentric which allows you to move the large gear closer to the smaller gear. This may have been knocked out of place or the gear(s) stripped. Here is a basic diagram of the parts.
Cub Cadet 2166 steering parts
May 19, 2012 | Cub Cadet Garden
Steering, The right front axle and tire lean in as if I were turning the steering wheel in the left direction but the left axle and tire remain straight. If I turn sharp to the left the right tire turns...
1) there are also bushings which hold the axle assembly into the front cross member, take a look at those.
2) while you are at it, replace the front wheel bearings on both sides
Aug 07, 2011 | John Deere Garden
Front wheels on craftsman lawn tractor are in two different directions after hitting fence. The one that hit the fence is in a 45 degree angle and the other is straight, how can I realign these.
It depends on if you just bent the tie rod (the rod that goes between the wheels) or if you bent the spindle on the wheel that hit. Look under the front and see if the tie rod is straight. If not, take it off and straightened it. If it is straight, you probably bent the wheel spindle. But also check the axle on the end that hit to see if it is twisted.
Jun 07, 2009 | Craftsman Garden
Agri-Fab Agri Fab Spreader Logo
67 people viewed this question
Top Agri-Fab Garden Experts
Joseph Mueller
Joseph Mueller
David Ellis Rhea
Ray Smythe
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
