Question about Zanussi FJS1225W Front Load Washer
Smell i am getting a bad egg smell for the 1st 5 minutes of the was cycle. Can you help
  • 641 Answers
Make sure that the drain hose is connected correctly, and that there isn't a direct run down from the sink u-bend to the washing machine. This can allow some of the dirty water running down the sink to run down the drain hose into the washing machine. A drain hose that is connected to a sink u-bend should first go up at least 3 or 4 inches high (it may need tying up) before running down to the washing machine. Good luck
Posted on Sep 13, 2007
SOURCE:
How do you hard boil eggs in this insta pot?
  1. Pour the water into the pot, and place the eggs in a steamer basket if you have one. If you don't, just use the rack that came with your pot.
  2. Close the lid, set for 5 minutes at high pressure.
  3. It will take the cooker approximately 5 minutes to build to pressure and then 5 minutes to cook. I let the pressure naturally reduce for an additional 5 minutes after the cooking cycle completed, and then did a quick pressure release. That's around 15 minutes, total.
  4. Place the hot eggs into cool water to halt the cooking process. You can peel immediately, or wait-- it's up to you. (The first time I did this, I didn't plunge into cool water, and they still peeled very easily. The eggs were just slightly more cooked.)
Mar 15, 2018 | Kitchen Appliances - Others
Top load washer smells like rotten eggs when water is draining into tub
As someone who has had a deep well drilled and found water, but water contaminated with iron and sulfur, I can tell you first hand about the rotten egg smell. The water softener will remove the iron that can turn clothes orange, but doesn't do anything to remove the rotten egg odor. You will need a charcoal (carbon) water filter to eliminate the sulfur smell.
Sep 19, 2014 | Whirlpool WTW8600YW: 4.6 cu. ft. Cabrio...
The vehicle is surging going up hill like a jerking almost ,and smell of eggs is bad,what do you think
usually when you get a smell like rotten eggs, it is your catylist convertor. if bad it is like it plugs up and causes drivability problems. take it to a muffler shop to get it checked out. Good-Day!
Jun 10, 2014 | 2004 Mitsubishi Endeavor
My car has been having a bad rotten egg smell for the past 3 days. It's only in the cabin that it smells like rotten eggs. under the hood no smell and the exhaust smells normal. One more thing to add,...
that smell is usually a sign of the catalytic converter which is the first wide muffler looking thing under the engine after the first pipe from the engine.
Nov 05, 2017 | Mitsubishi Cars & Trucks
Smells like rotten eggs
it is happen to old engine because the oil that escape from the engine(engine cover near the exhaust) when it is got hot it sends bad smell but after how many minutes if it already dried up because of heat it will gone (like frying using the used cooking oil in pan there is a different smell).
Sep 19, 2013 | Mitsubishi Cars & Trucks
Truck is giving off a rotten egg smell !
rotting egg smell is associated with your cat converter going bad
Jun 24, 2013 | 2004 Cadillac SRX
My 2002 Pontiac GP V6 smells like rotten eggs from the exhaust
The rotten egg smell if it is coming from the exhaust is a very good sign that you catalytic converter has failed or is failing. but a bad or battery that is being overcharged can also make a rotten egg like smell.
Jun 05, 2011 | Pontiac Grand Prix Cars & Trucks
Rotten egg smell in my dishwasher
Yes mold and rotten food in the filter screen at the bottom of the dishwater water tube
Oct 16, 2017 | Hotpoint 24 in. HDA3740G Stainless Steel...
Egg smell in my water
spray ammonia in the bottom, try running a normal cycle, this should eliminate any odors.
Sep 03, 2009 | Viking Dishwashers
V6 fuel injected. losing power after 1st gear, very sluggish low rpms
Have you cat converter checked. If your exhaust smells like rotten eggs or sulphur, it's bad
Jul 25, 2009 | 1990 Acura Legend
Zanussi FJS1225W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
