My laptop screen is very dim, cannot read or see looks faded
When I pull up my laptop the screen is very dim. Not ledgeable
  • 2,404 Answers
Try using the brightness controls on your keyboard to brighten the screen. If that doesn't work then that means either the lcd or the inverter has gone bad.
Posted on Apr 14, 2009
I have acer laptop 5750G. It has a very dim light. tried to adjust the brightness but to no avail..
One thing that I can suggest to you that may save you money is to try a external monitor rather than repairing it at the moment.
Sep 26, 2015 | Acer Computers & Internet
Reciept side ink not printing
Need a new ink cartridge. Just like any printer they do not last forever before it needs changing and faded ink is classic sign that is the case. Skipped spots but good darkness would indicate some thing is dirty instead but that is not your situation.
Apr 15, 2015 | Sharp Royal Alpha 9155SC Cash Register
Screen is faulty. It divides in equal half and displays well on one side and dims on the other. I can read info on both sides but dim side displays faded colour. External monitor works fine.
Usually not. The circuitry that drives the panel is integrated with the screen.
It's some work but those screens are serviceable and you can often find a good replacement on eBay at a fraction of the cost of a new HP part. A local small computer shop could probably swap it out for you in less than an hour.
Good luck.
Apr 08, 2015 | HP 6440b Notebook PC - Core i5 430M 2.26...
How to brighten up my screen, my screen says its up all the way, but its still very dim. & it was fading in and out before,.
Looks like the inverter is on its way out.
Seek the brand service center for replacement as inverters are really hard to find.
Jan 04, 2010 | Computers & Internet
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
Screen gets dim at times.
Backlight is going bad.
Either bulb or whole LCD needs replacement.
But, first start with new/good Inverter Board.
Apr 14, 2009 | HP Pavilion zd7010us PC Notebook
The display has dimmed, and looks washed out (faded)
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 05, 2009 | Toshiba Satellite 4010CDS Notebook
DIM SCREEN
It can be the inverter, or the backlight, ar also the switch that de-activates backlight when you close the laptop.
Read here : LAPTOP MONITOR SCREEN VERY DIM OR DOES NOT ...
Oct 16, 2008 | Computers & Internet
No light on screen of acer extensa 4620 4605 PC notebook
Try to find the button that tells the screen to come on. This sticks sometimes on laptops. I always tell people not to use canned air because it only blows dust around, but it could help your problem. If you are okay with taking it apart you can find this button and see if it is sticking. This is becoming a common problem with laptops. I recently had a customer with this problem and it took me some time to figure it out. It is usually around the hinge. Look at the manual if you can't find it.
Jun 02, 2008 | Acer Aspire 5100 Notebook
Screen is dim
Try looking for a function key (usually used by holding down the Fn key and then pressing one of the "F" key at the top) the key will be marked with a brightness indicator.
Is your screen only dim when running off the battery is it dim when running when the charger is plugged in as well. If it is only dim when the laptop is running on battery then this may be caused by a setting in Power Options which is located in Control Panel (that is if your running Windows). In Power Options look for settings about running on AC Power and running on Battery power.
Jan 07, 2008 | Dell Inspiron 8500 Notebook
Computers & Internet Logo
316 people viewed this question
David Payne
David Payne
