Question about Brother HL-2040 Laser Printer
BROTHER 2030 TONER LIGHT STAYS ON CONTINUOUSLY
TONER LIGHT STAYS ON ALL THE TIME SINCE TONER RAN OUT NEW ORIGINAL TONER IS NO DIFFERENT AND LIGHT STILL STAYS ON THANKS
  • 1 more comment
  • KarinDPowell Jan 10, 2012
    Works with Brother HL-2270DW wireless printer also.
  • Anonymous Mar 24, 2014
    New cartridge toner in now printer toner light stays on
  • Anonymous Mar 25, 2014
    toner light stays no printing
I had the same problem and Brother tech support walked me through this procedure which worked fine..
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Posted on Oct 24, 2007
  • 1 more comment
  • Elizabeth Craven
    Elizabeth Craven Jun 28, 2012
    Nathan, you are my savior. It worked!! Yay! Hooray. I thought we had to send it back. Brand new.
  • Warren Kennedy
    Warren Kennedy Oct 16, 2012
    You are a legend
  • David Fontes
    David Fontes Mar 28, 2014
    thank you veryy much !!!!
I been having the same problem recently & tried every available method...The i read this on another website and thought I must share with everyone...Simply paste a little piece of Post-it and cover up the hole at the left side of the toner..And so far I restarted the printer 3 times and the toner light is not on any more!!!
Posted on Feb 21, 2008
  • boomster Feb 22, 2011
    You rock! Have been dealing with this problem for a while. Brother tech support just said purchase more toner - no fading in printouts so toner appears to be present but toner light doing that face-plant. I asked Bro support if they knew where the sensor was and could I check / defeat that. This was above their idea of technical help. Put that piece of post-it over the hole and I am saved!
Toner cartridge wiil not come out? paper is jammed brother 2030
You need to open the front door and grab the toner/drum unit and pull as hard as you need to. once the assy. comes out you press the blue button on the left side and the toner cartridge will separate from the drum unit. install the new toner or remove the paper jam as required. call if you need more info. 805-520-3003 steven
Feb 13, 2010 | Brother HL-2030 Laser Printer
How do i add toner to my hl 2030 brother printer ?
You don't "add" toner, you have to replace the cartridge. You can see it by clicking on this link:
HL-2030 Toner
You can refer to the User Guide for instructions. here is a link to it:
HL-2000 Series User Guide
Replacing the toner is covered in Chapter 5.
Thanks for using Fixya.
Jan 09, 2010 | Brother HL-2030 Laser Printer
Brother HL-2030 continually prints test pages
disconnect the printer from your pc and clear out all print jobs... leave it on and let it sit for a day... if no test page prints then the problem is your pc... if it starts printing like crazy then reset it via page 54 of the user guide if it still prints like crazy with the network cable or usb cable disconnected then you need to call brothers tech support but more than likely it shouldn't do anything... if this is the case... the problem is your pc... or your server...
Dec 20, 2009 | Brother HL-2040 Laser Printer
My Brother HL-2030 won't work; All LED lights are flashing
Use the software to diagnose the problem or check for a paper jam and ensure the drum and toner is OK.
Dec 11, 2009 | Brother HL-2030 Laser Printer
Drum light on HL2030 won´t go off!
Open the front door, and press the go button until the lights flash, after closing, press the go button 3 times for a printout showing the drum as full again. The instructions come with the new drum...
Jul 30, 2009 | Brother HL-2030 Laser Printer
I have changed the toner in my printer and the toner light continues to stay on/won't print. I tried changing the drum and still the toner light stays on/won't print. I tried opening the toner door and...
No guarantee this will work but I refilled toner on my Brother 5170 and it only worked after making sure the old stuff was completely out. After removing the little plastic plug, I tapped out the toner repeatedly on the side of a trash can (like 50 times) then took a shop vac and let that **** out whatever toner was left. It really seems to be important for some reason to rid the cartridge of ALL old toner before adding the new stuff. Hope this helps!
Feb 23, 2009 | Brother HL-2040 Laser Printer
Brother hl-2030
Hi from what i have read on the internet and past experience with these printers (our company has 20 -30 of them) the fault is within the printer and requires a service call from brother.
if its still under warrenty i would suggest taking it back for a replacement if that is not possible but its still under warranty ring up brother in your country and get them to send out an engineer. we have just had another one of our printers start doing this after some routine maintance (we simply used compressed air cans to clean out any "rubbish where the toner / drum assembly goes) after that the printer is now flashing all 4 lights.
sorry i cannot be more positive about the problem but as mentioned its a fault within the printer that requires an engineer.
Aug 13, 2008 | Brother HL-2030 Laser Printer
Toner cartridge
pl z visit following site for help
http://es.alatest.com/Printers/Brother+HL+2030/pro-reviews/
Dec 26, 2007 | Brother HL-2040 Laser Printer
False detection of toner low
The only remedy you have now is to change the sensor , for this you have to refer to the product manual you can download it from
http://www.brother.ca/en/products/pdf/QSG/HL2030-QSUG.pdf
Good Luck
Dec 05, 2007 | Brother HL-2030 Laser Printer
BROTHER HL - 2030
The solution that you tried, does that mean that you purchased a new brother toner and fitted to machine?
Dec 03, 2007 | Brother HL-2040 Laser Printer
Brother HL-2040 Laser Printer Logo
7,838 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
