Question about Canon Pixma iP2600 Photo InkJet Printer
Ink and printer
I had color and black ink and the color ran out so i took it out and changed the settings to use just black ink and it will not let me print. it says i need to install the color and i already threw it away.
I had problems after two years of refilling ink cartridges. The usual.
In order to refill a cartridge (In this case the 30 black & 31 color) you must remove the original paper covering on top of either or both cartridges to expose the original fill holes.
On the black (30) cartridge, I did so and then enlarged the original fill hole to accept my syringe needle for refilling. NOW...this is imperitive, replace the paper covering and tape down with clear tape.
On the color (31) cartridge, I did the same routine and enlarged the three original fill holes. Filled each of the color partitions and again replaced the paper cover which was removed to expose the fill holes. Works like a charm.
I found out the paper covering MUST be replaced when I decided during completion of refilling the color (31) cartridge that taping the paper covering back on was not necessary. WRONG!!!! I immediately got the same error problems everyone else is complaining about. Got 1 green then 7 orange flashes. I reset the printer and got l green then 5 orange flashes. Etc. Replaced the paper covering and after several minutes of cycles (I could hear the printer cycles) it finally asked if I wanted to discontinue the ink level capability. I clicked OK. Then after a couple more minutes of cycling the printer was again ready to print.
Now having no problems. I have refilled both black and color cartridges many times. Used up two or three color kits and allmost all of a 16 oz. black ink container. Print heads still doing a great job.
Guys, I hope this helps you. Appears to me the paper covering of the cartridges holds the secret. My advice...put them back on carefully so printer can "read".
Cordially, Soryxxs (ebay user I.D.)
Posted on Apr 22, 2009
    President:
  • 415 Answers
You'll need to either put it back in or replace it.
You need to have both color and black cartridges in for your printer to work.
Never throw away cartridges, save money and refill them or you can take them to most any computer store for recycling.
Mark
Posted on Apr 14, 2009
My printer is not printing
Go to the setting on the printer and go to maintence or option ink? set it to both color & black. If you are only using black set it to black only depending on what you have on the ink cartidge. I hope this was helpfull.
Jun 08, 2009 | Epson Stylus C62 InkJet Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
MFC-420CN does not print black
My yellow cartridge was doing the same thing as your black. So I took the cartridge out, and took a flashlight to see how it works. There is like a little straw on the right hand side which goes up into the printer cartridge, this I assume is to measure the ink. I took a needle and cleaned that 'straw' thoroughly. Reseated the ink, ran cleaning and test print, and then the printer found the yellow ink! You could give that a try. It might work for you too. (I have never used any ink but Brother ink in the printer, btw.)
Apr 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
How to convert the color printer to Black?
No,sorry. Even if the print looks like it should use black toner only,it uses a little of color toner depending on the shade .
This is also true for other laserjets and inkjets
Hope this helps
Mar 31, 2008 | HP Color LaserJet 3500 Printer
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
After changing cartridge, printer will not print, z645?
First... check to make sure you removed the yellow tab from the new print cartridge
put the ink cartridge back into the printer
click Start
click Control Panel
open Printers and Faxes
click (or double click to open) your printer icon
click on Printer menu
click on cancel all documents
Then try printing again.
If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
354 people viewed this question
old marine
old marine
