Question about Scotsman Cooled Modular Contour Cuber Remote Condensed 425lbs
Scotsman cme506 Bin light is on all the time. I cleaned the sensors and light stays on. Compressor runs a few seconds and stops.
  • 1 more comment
  • aztecainc Apr 14, 2009
    no error code lights. no blinks!
    Just the bin light on. Even when i turn on the machine all lights blink, then only the bin light stays on. i press freeze, bin light stays on. compressor starts running and the machine turs off a few seconds later
  • steve
    steve May 11, 2010
    Sounds like cleaning will not help.
    Replace the bin sensor lights. They must be shorted. It happens.
  • steve
    steve May 11, 2010
    Are you getting any error code lights?
    If so, how many blinks?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 107 Answers
Change the ice bin sensors they are infrared sensors and they are not working.If you have already taken them out and cleaned them replace them.Those sensors are 75 percent of all my service calls on this perticular unit.
Posted on Apr 20, 2012
I service scotmen cme506 blink 2 times in the water iclean bin sensors check water lebels install new inlet valve and due same
Posted on Mar 31, 2011
I have a Scotsman cme506 I'm already replace the two bin sensors and the main control but the problem still full bin light. Never turns off do some know what I can do pls ???
When you replaced the CM3 Universal service controller did you set the right setting on the selector switch on the side of controller? The program selection table is on the back. Also make sure the wires on the din eyes are not grounded to the cabinet of machine and do not cut the wire and splice them.
Nov 04, 2014 | Kitchen Appliances - Others
Bin full light stays on
You need to pull the bin full sensors and clean or replace them. Pull the front cover off remove the ice deflector you will see the water sump tray pull the ice deflector grate out of sump. Now where the ice fall into the bin on the right and left side in the shout there is 2 sensors they will pull out sideways, they will both have a wire ran to them pull wire and sensor up to where you can see the red sensors om them take a descale solution Scotsman brand mix per instructions and clean the eyes now would be a good time to clean and disinfect the whole machine. Install them back and start machine if this dose not clear the bin full light then replace them.
Jan 16, 2014 | Scotsman Cooled Modular Contour Cuber...
Scotsman cme 1656 bill full stay on after cleaning
Ok did you damage the bin thermostat cap tube? The bin thermostat is what tells the unit the bin is full if so replace it.
Nov 14, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Scotsman CME506 will not stop making ice
Replace the bin control sensor set of two. Part number 11-0540-21. The bin control sensor is not sensing that the bin is full.
Aug 03, 2013 | Kitchen Appliances - Others
CME456AS-1C BIN FULL LIGHT ON BIN EMPTY MACHINE RUNS FOR 1 MIN THEN STOPS
clean the ice sensor on either side of the ice platen and just past the water trough. gently pry the sensor on each side out of their plug and work wiring out until you can get to the two led lights and clean scale off. limestone scale builds up and blocks the sensors.
Dec 27, 2012 | Scotsman Ice Maker 600LB CM3 30inW...
Bin Full light stays on all the time
This is usually an indication that the photo eyes are probably dirty. They "See" across the opening where the ice drops through. If they are dirty, it registers as a fill machine.
A bin stat can cause the same problem.
The eyes and sometimes be a major problem finding them getting to them. On smaller machines like this one, it's hard to get your hands on them.
Good Luck and hope this helps.
Jan 08, 2009 | Scotsman Freezer Clear Icemaker w/ Pump
Scotsman Cooled Modular Contour Cuber Remote Condensed 425lbs Logo
771 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
